Selling a complete Trick Flow R EFI Intake for a 302 Small Block Ford. Has Part #TFS-SBF-EFI-3U cast in it. This is a R model with the 75mm throttle body opening. Will also come with 1" Trick Flow Spacer for between the upper and lower intakes. Intake was removed from a car I recently purchased and appears to have seen very little use.
Additional info can be found on Summit's site:
Intake - http://www.summitracing.com/parts/tf...1003/overview/
Spacer - http://www.summitracing.com/parts/tfs-51520012
Asking $450.
