Results 1 to 10 of 10
Thread: cobra mass air
    87 foxbody mkwood4's Avatar
    Oct 2011
    aliquippa
    190
    cobra mass air
    im working on a 92 5.0 we did hci and 24lb injectors we bought a bbk meter and housing for 24s but i was wanting to know if i could use a oem meter from a 93 cobra?
    1987 mustang lx/gt
    2010 nissan xterra
    2001 ford f-150 super crew
    Sep 2007
    Dayton PA
    3,795
    no, you need the cobra computer and MAF to make the 24s work correctly.
    03 Torch Red Anni. Ed. Cobra
    01 cobra: traded
    93 LX Modular 4v swap
    Apr 2011
    youngstown, oh
    47
    why would you need the cobra computer as long as everything is matching injector and meter then should work fine, if you did have a computer out of a cobra it is programed differently then maybe even a little more agressive, but you could manage the same out of gettng a chip and tune too.
    Your mom cwh19's Avatar
    May 2009
    Greensburg
    1,383
    Quote Originally Posted by gerbenitz View Post
    If you got a chip and tune then you wouldnt need the computer. However to just use it without the tune you would. The 93 cobra computer is a different part number than the other 87-93 ecus. I believe using that meter without the comp is no good.
    15gt
    94gt
    Apr 2011
    youngstown, oh
    47
    How's it any different then running 42# injectors with a meter setup for 42# injectors on a stock computer no chip as an example. My car ran fine for years like this single turbo hci setup sure it would have probably make more power with a tune but started and ran perfect.
    Sep 2007
    Dayton PA
    3,795
    thats because you bought an aftermarket MAF that is calibrated for the larger injectors and the GT computer. the MAF from a cobra wont work with the GT computer properly, half of the information for the injectors is in the computer and half is in the MAF. he would need to buy an aftermarket MAF calibrated for the GT computer and 24lb injectors or get a tune.
    01 cobra: traded
    Petersburg,PA. 16669
    816
    Mass air off a 93 cobra will work fine with 19's.The mass air has nothing to do with the 24's.I have ran a copule of them and work fine.You need to X3Z computer from a 93 cobra. The calibration for the injectors is in the computer unlike any other computer for a fox body. Every other computer is calibrated for 19's
    88 GT...and some boost
    816
    But if you use the X3Z you have to use a 19# meter or the cobra meter.I would just stay away from the computer all together
    May 2009
    Greensburg
    1,383
    Qft.
    15gt
    94gt
    Sep 2007
    Dayton PA
    3,795
    So the cobra MAF and the GT MAF will output the same voltage at the same air flow? I was under the understanding they only work with the computer they were paired with. taking a sample of the air velocity in a large diameter compared to sampling the velocity in a small diameter and if the velocities are the same your still going to get more air volume passing through the large diameter MAF. Not unless ford did skew the voltage differently out of the Cobra MAF than the GT....maybe so?
    Thats only reason the "calibrated" MAFs work is they skew the voltage output
    01 cobra: traded
  1. Replies: 1
    Last Post: 04-16-2013, 08:59 AM
  2. FS: 89 Mass Air Harness and A9L Mass air computer
    Last Post: 01-07-2012, 07:54 PM
  3. WTB stock 94-95 cobra mass air flow meter
    By 94svtcobra in forum Ford Parts
    Last Post: 08-04-2008, 09:26 PM
  4. 5.0 throttle body, mass air, 93-95 Cobra manifold gaskets
    By WickedJester in forum Ford Vehicles
    Last Post: 05-23-2008, 12:01 PM
  5. fox mass air vs sn95 5.0 mass air?
    By scott5 in forum Fox-SN95
    Last Post: 07-13-2007, 10:19 PM
