Results 1 to 19 of 19
Thread: clutch fork rattling
    Aug 2010
    connellsville
    160
    Angry clutch fork rattling
    IWell guys I just got done doing the 5 speed swap to my 91 gt ( or so I thought) . I started the car to test it out and for some reason I was getting a rattling sound coming from under the car. At first I though was the pedal cause it is a little worn. So I jack the car up to inspect the fork and I notice that the fork is rattling up and down hitting the sides of the inspection hole the fork goes through. Also when I push the clutch in I can feel and clunk about half way into it. It has a brand new sve mongoose clutch kit, clutch fork, pivot stud. New steeda couch cable kit. It seem to be engaging and disengaging property it will rattle while its in neutral or in gear while the pedal is out barely put pressure on the pedal it stop. What the hell could it be
    Senior Member ttk53's Avatar
    Sep 2008
    369
    Is it hitting the back and front or top and bottom, Are u sure the fork is clipped into the pivot ball?
    Aug 2010
    connellsville
    160
    Top and bottom
    Your mom cwh19's Avatar
    May 2009
    Greensburg
    1,383
    Quote Originally Posted by ttk53 View Post
    This is what I was thinking. Might not be clipped on correctly.
    15gt
    94gt
    State College, PA
    3,552
    x3. I bet you have one side of the clutch fork clipped in and not the other. See the two fingers on the clutch fork here: http://ddperformance.com/shop/images...s/100_0142.jpg
    One might still be in front of the pivot ball and the other behind...
    2013 Mustang GT
    1999 Contour SVT
    Aug 2010
    connellsville
    160
    I started to think the same thing i‘ll probably pull it apart tomorrow evening I'll keep you guys updated.
    Aug 2010
    connellsville
    160
    update: pulled the trans this evening as i got the front shaft out the fork dropped to the bottom of the bell. i tried clipping it back on but it doesn't seem to want to lock on. its the same fork in the picture above i got it from LRS. pulled the trans from under the car and noticed the from bearing retainer was grooved pretty bad. so i'm thinking thats the reason for the clunking sound when i push the clutch in. do you guys think that would also cause the rattle at the fork since the bearing is riding on a uneven surface.
    Aug 2010
    connellsville
    160
    Aug 2010
    connellsville
    160
    Anyone?
    May 2009
    Greensburg
    1,383
    Thats grooved in the input shaft? I honestly dont know what would cause that.
    15gt
    94gt
    Aug 2010
    connellsville
    160
    Yeah its the bearing retainer that doubles as a sleeve for the throw out bearing to ride on. There made of aluminium so after 20-25 years they wear out i'll be ordering a new steel on this week. The input shaft is fine very very little play.
    State College, PA
    3,552
    that bearing retainer looks horrible. Definitely replace that. I would replace the throw out bearing too, because it probably got screwed up sliding on that retainer. Did you grease the throw out bearing/retainer? You should do that with a LITTLE bit of grease.
    And how about pilot bearing? Did you put a new one in when you did the swap?
    2013 Mustang GT
    1999 Contour SVT
    Aug 2008
    duquesne
    544
    the throw out bearing is getting hung up on your input bearing retainer causing all kinds of issues, unfortunately you need a bearing retainer, just make sure to use the correct shim when replacing the bearing retainer,
    -greco
    92 Coupe, 10.72@133
    Aug 2010
    connellsville
    160
    Thanks guys the pilot, throw out , pivot ball, fork are all new that only thing that isn't is the retainer. I'm picking a new one up today. Do you think I should put a new tail shaft bushing in while its out. I called a local tranny shop and they said $100 for the bushing, seal and to put it in.
    I'd still replace the TOB.
    Aug 2008
    duquesne
    544
    yes replace the tailshaft bushing while its out, insurance
    -greco
    92 Coupe, 10.72@133
    Aug 2010
    connellsville
    160
    Got the retainer and bushing put in at another tranny shop for half of what the other guy wanted. Hope to get the trans back in the car tomorrow.
    Aug 2010
    connellsville
    160
    Car is back together and running great thanks for the help guys.
    State College, PA
    3,552
    Quote Originally Posted by geps91stang View Post
    Glad to hear it worked out for you. The weather is finally nice, enjoy driving it!
    2013 Mustang GT
    1999 Contour SVT
  1. Clutch fork question
    Last Post: 12-01-2012, 09:42 PM
  2. D9 Clutch fork
    Last Post: 07-30-2011, 07:01 PM
  3. Clutch Fork Cover
    By frankstang in forum Ford Parts
    Last Post: 09-18-2008, 08:25 PM
  4. Pivot ball & clutch fork tech question
    By 94Cobra in forum General Tech
    Last Post: 01-04-2008, 08:45 PM
  5. Wtb: Bellhousing And Clutch Fork
    By Uncle Tom in forum Ford Parts
    Last Post: 09-23-2007, 04:40 PM
