Results 1 to 9 of 9
Thread: 89 GT A/C Advice
    Junior Member
    Apr 2013
    6
    89 GT A/C Advice
    In order to pull the engine on my 89 GT, I'll have to discharge the A/C refrigerant and plug the lines to the compressor. I had it retrofit to 134A a few years ago. I'm a fair mechanic, but have never fooled with A/C. The Ford service manual was written for the old style system and was not much help.
    I've been wanting to buy the equipment to recharge the system myself anyways. Would this equipment discharge the system? Any recommendations as to equipment or on-line tech help? Thanks.
    Senior Member Dan B.'s Avatar
    Armagh, PA
    4,331
    Just set the stuff to the side. You don't have to break the system open.
    Ahh fuque
    1986 Ranger--2WD, 5.0/T5/8.8.
    Junior Member
    Apr 2013
    6
    It looks like two rigid lines run from the firewall to the compressor. Seems like it would be best to get these out of the way. The system needs recharged anyways, so I think I'd prefer to get them out of the way.
    Aug 2010
    Greensburg, Pa
    390
    just eliminate the ac.....less weight more power plus looks cleaner
    Daily: 2007 Ford Fusion SE
    Brookline
    2,897
    Quote Originally Posted by Erics89GT View Post
    x11ty billion
    Member torqueboxer's Avatar
    white oak, pa
    638
    If you open up the system you gotta replace the air dryer if you want good performance ( it's the can that hangs behind the pass side valve cover). When it gets exposed to air the desiccant will soak up moisture and not work well anymore
    Junior Member
    Apr 2013
    6
    Thanks for the tip. Could I vacuum out the system, remove the lines to the compressor and plug what's left to minimize moisture intrusion? I'm not sure how to capture the refrigerant though. Or is 134A safe to release into the atmosphere?
    white oak, pa
    638
    You really don't have to open up the ac to pull he motor. If you want to keep the 134a then you need a vacuum pump/ manifold set/ empty refrigerant bottle. Depending on the size of the pump you buy it'll probably take 1/2-1 hour to evac he whole system I'd save the 300-500$ on he ac tools and put it toward some performance parts
    Junior Member
    Apr 2013
    6
    Thanks Bud, I'll just leave it hooked up.
  1. help!! all advice taken
    By ERHsn95 in forum Fox-SN95
    Last Post: 06-13-2012, 06:59 AM
  2. I need some advice
    By ERHsn95 in forum Autocross & Road Racing
    Last Post: 03-06-2012, 07:34 AM
  3. 94 need advice
    By RogerStout in forum Fox-SN95
    Last Post: 04-14-2011, 11:20 AM
  4. advice here all
    Last Post: 01-30-2009, 09:19 PM
  5. Need advice
    By macs02gt in forum SN95-New Edge
    Last Post: 12-11-2006, 07:08 PM
