Results 1 to 20 of 31
Thread: Rebuilding my T5 WC...Any input appreciated
    '87 Tangerine GT 50Dro's Avatar
    Jun 2010
    Cranberry Twp, PA
    191
    Question Rebuilding my T5 WC...Any input appreciated
    My T5 WC (from a 93 GT) decided that it didn't feel like letting me into 3-4 late last year so I've decided to rebuild it. Taking it all apart I found lots of play, leaking rear main, bad clutch, p-plate, fly-wheel, broken shifter fork, worn shifter etc etc...Looks like this is gonna be a $1000+ job! :(
    Since the rebuild kits don't include new shifter forks, can any of you tell me where you have gotten new ones? Am I locked in to the dealer on that? I have a Ford book that shows that all 3 forks are the same PN but the dealer tells me they are not. 1-2 & 3-4 are $70+ and 5th/R is around $40. What have you used?
    Any other general info on the rebuild is appreciated. I'm not a stranger to rebuilding things but this is a first for me...
    Thanks!
    Petersburg,PA. 16669
    816
    Find a good used one and replace all the fork pads. They make a seal and bushing kit for the tail. I would replace both. If you have a stock shifter that is most likely where the broken shift fork came from. By yourself a good shifter. If you have alot of play check the inpuf shaft and cluster gear teeth and make sure they arent worn.
    88 GT...and some boost
    Jun 2010
    Cranberry Twp, PA
    191
    Thanks! I was gonna use the Ford Racing rebuild kit that has all that in there I believe. I had an older Hurst shifter on there but the rubber ball where the shifter pivots had A LOT of play in it. That could have been the cause...Thinking I'll replace it with the MGW shifter.
    Since I wrote this I actually found a few sites that sell OEM new shifter forks for around $20! I'll share some links and info later. You can buy brass fork pads too...
    816
    The springs in that shifter are broke. Happens all the time. They make a kit for it to replace them. The shifter might be wore as well so might just be better to buy a new one. I like the old hurst and pro 5.0
    Jun 2010
    Cranberry Twp, PA
    191
    Interesting! Do I have to go directly to Hurst for the replacements or does Summit etc sell them?
    816
    Summit should or anyone that sells hurst stuff
    Senior Member ttk53's Avatar
    Sep 2008
    369
    http://www.summitracing.com/parts/fm...view/make/ford why not get something like that.
    Probably could get it even cheaper from someone like tousley ford
    Jun 2010
    Cranberry Twp, PA
    191
    The bulk of the cost is everything in front of the trans (clutch kit, fly-wheel etc plus a new shifter). The parts to rebuild the T5 itself will be around $400. Thanks though.
    Sep 2008
    369
    oh missed that part. I hate T5's In high school we rebuilt my buddies at least once a month it seemed lucky we had a friend who owned a ford dealer that had piles of T5's to sift thru to find the parts we needed.
    Jun 2010
    Cranberry Twp, PA
    191
    haha! I guess I'm lucky then...Been beating the pants off of this one for the better part of 15 years! Of course I don't put many miles on each year but the miles are hard ones! ;)
    i still have the rebuild kit
    Member HOTMARK7's Avatar
    BUTLER PA
    148
    Have a complete t-5 torn down, used a syncro out of it , you can have it for parts, just come and get it. Ron 724-991-9084
    Aug 2010
    Greensburg, Pa
    390
    i need a t5 myself.....im looking for a good one to drive or one for parts
    Daily: 2007 Ford Fusion SE
    Jun 2010
    Cranberry Twp, PA
    191
    Update: Out of curiosity, I took the Hurst shifter apart. The springs were fine but I discovered that the section of the main casting that the pivot of the shifter handle rests in was cracked so a new shifter is a definite. MGW here I come! :)
    I also found some great sources for T5 parts and knowledge. I've talked to people at 2 of the 3 and they were extremely helpful. Here's some links:
    http://www.thegearbox.org/T5.html
    http://www.allstategear.com/Ford_Mus...ansmission.htm
    http://www.astroperformance.com
    Keep in mind that Borg is owned by Tremec and therefore most of the FRP stuff out there is just re-branded Tremec or Valeo parts. These guys have the shift forks for <$20 each ($70+ at the dealer) and King Cobra clutch kit for only $149 ($219 at Summit & Jegs etc) ! Definitely give them a try if you're in my shoes.
    Furthermore, Aero (thanks Ron!
    ) has re-manufactured transmissions that will handle 450 HP & 350 Tq for around $1400 if you want to go that route. I never knew you could build a T5 that strong!
    I'll post more as things progress...
    Senior Member fox fan's Avatar
    Jan 2010
    Washington Pa
    235
    I think Astro builds 1 to handle 650hp/585 torque now. But it's not cheap.
    816
    Quote Originally Posted by fox fan View Post
    Thses arent that cheap but are the best T5 you can buy. Far better quality than G Force and the gear teeth are alot thicker and the oiling holes are alot better as well
    Jan 2010
    Washington Pa
    235
    Yeah I'll probably end up with 1. They say they shift great.
    816
    Mg friend has built several of them and they all came back with nothing but great comments
    Jun 2010
    Cranberry Twp, PA
    191
    Astro has been a HUGE help for me! I'd definitely recommend them.
    Jan 2010
    Washington Pa
    235
    Turbosnake93?
  1. Looking for pistol input ...
    By mr4teth in forum The Bar
    Last Post: 05-13-2012, 11:12 PM
  2. Rebuilding a tranny
    Last Post: 04-05-2010, 06:08 PM
  3. Exhaust Input
    By Shanehead89 in forum General Tech
    Last Post: 06-11-2009, 03:25 PM
  4. Need some input
    By Stangin in forum General Tech
    Last Post: 10-24-2007, 10:55 AM
  5. Input on this 302 out of the '84
    By Ares in forum Fox-SN95
    Last Post: 05-28-2007, 09:55 AM
