Results 1 to 17 of 17
Thread: 10.72 @133 4500rpm trap speed makes power to 6k GEAR CHANGE???
    Aug 2008
    duquesne
    544
    Project coupdy made its debut 1/4 mile appearance yesterday, gonna do a gear change but the car went 10.72@133 with 3.27 rear gears and a 1.72 60' going through the traps at 4500rpm in 4th, car likes to be shifted at 6k, what do you guys think 3.55's or 3.73's?? Thanks, Mike
    -greco
    92 Coupe, 10.72@133
    Apr 2010
    South Hills
    3,579
    Sounds like a monster Mike! Last time I saw that car it was in a million pieces at your old place. Came a long way.
    -Barry
    Polar Vortex
    6,031
    3.55's
    Good job, i spoke with u. im the guy in the white vert cobra.
    03 cobra oxford white
    05 Srt4 neon. 10.29@137. Best mph 142 (sold)
    Senior Member Cam99's Avatar
    Melcroft
    4,178
    Id say 3.73's would be perfect. say you running last night. You were hauling the mail
    At the same MPH(133) 3.73's will only bump you up to a little over 5100 RPM crossing the stripe if you're at 4500 now. I think 4.10's would put you closer to where you want to be. They would put you at around 5650 RPM at 133 MPH with room to grow to 141 MPH at 6000 RPM if you run a little better down the road.
    Atleast 4.10's maybe even 4.30's
    With a really deep gear - say 4.10 plus - are you going to be able to hook or will you be spinning a lot between gears?
    Aug 2008
    duquesne
    544
    I have the 3.73's so I'm going to give it a shot. Unless someone has some 4.10's they wanna trade?
    -greco
    92 Coupe, 10.72@133
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    What tires are you running Mike? 28"?
    2014 M235i (wife's)
    1964 Ford F-100
    Aug 2008
    duquesne
    544
    After doing some math, one of two things are going on, either clutch slip or tach is off, the math don't lie, should have been at 5500 with 3.27's 133mph 26.5 tire
    Sent from my SCH-I405 using Tapatalk 2
    -greco
    92 Coupe, 10.72@133
    Aug 2008
    duquesne
    544
    I should , had no tire spin issues, just turbo lag issues trying to find the cars launch rpm. 5k is the perfect rpm to eliminate my blow thru's stumble
    -greco
    92 Coupe, 10.72@133
    Trafford, Pa
    2,308
    With 3.27s and a 26" at 133 it wouldn't be 4500. Tach off?
    2014 M235i (wife's)
    1964 Ford F-100
    i would say 3.55s then turbos dont like alot of gear
    Tach could be off - Aren't those fox tachs notorious for being inaccurate?
    Member torqueboxer's Avatar
    white oak, pa
    638
    Aftermarket tach..................................I say MORE BOOST!!!! I really shouldn't talk I only have 6lbs.:(
    Aug 2008
    duquesne
    544
    I just want to maximize my et with the current boost setting, then slowly turn it up (after the e85 switch of course)
    -greco
    92 Coupe, 10.72@133
  1. Gear change? 3.55 or 3.73's?
    By blksunshine88 in forum Fox-SN95
    Last Post: 06-08-2013, 10:55 PM
  2. Trap speed is kind've low for these ET's
    By Seer in forum Drag Racing
    Last Post: 07-08-2011, 10:22 PM
  3. 2011 Mustang 5.0 Makes More Power Than Advertised
    By mlowry1260 in forum Pictures & Videos
    Last Post: 03-28-2010, 07:39 PM
  4. Speedo fix due to gear change
    By 04mustang232 in forum General Tech
    Last Post: 06-24-2007, 03:39 PM
  5. What makes power brakes "power" ?
    By Troll in forum General Tech
    Last Post: 05-29-2007, 06:04 PM
