Results 1 to 11 of 11
Thread: Gear change? 3.55 or 3.73's?
    Aug 2008
    duquesne
    544
    Project coupdy made its debut 1/4 mile appearance yesterday, gonna do a gear change but the car went 10.72@133 with 3.27 rear gears and a 1.72 60' going through the traps at 4500rpm in 4th, car likes to be shifted at 6k, what do you guys think 3.55's or 3.73's?? Thanks, Mike
    -greco
    92 Coupe, 10.72@133
    RRT juice_man_86's Avatar
    Uniontown, PA
    533
    3.73's for sure
    Fuwkawee
    5,151
    Quote Originally Posted by juice_man_86 View Post
    3.73's for sure
    Another vote for 3:73's
    17 Ram 1500 Big Horn Hemi
    16 Comp O GT Performance Pack
    Aug 2008
    duquesne
    544
    This is a street driven stick car, I have 3.55's and 3.73's I'm going to do the 3.55 swap, get some passes and swap 3.73's to physically see what the car wants, I'm happy on top end with 3.27's but to help with lag off the line I want more up to the 1/8, also found out the tach was wrong, car was at 5500 in the traps, don't wanna go higher than 6100
    Sent from my SCH-I405 using Tapatalk 2
    -greco
    92 Coupe, 10.72@133
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    Then stay with 3.27s. Once you get the tune worked out the mph will likely come up, right?
    2014 M235i (wife's)
    1964 Ford F-100
    Aug 2008
    duquesne
    544
    Its not a tune issue, its an exhaust housing a/r issue at this point, if it were auto id be ok, have to roll the throttle since the motor goes extremely fat if the secondaries open before they see boost
    -greco
    92 Coupe, 10.72@133
    Trafford, Pa
    2,308
    Quote Originally Posted by blksunshine88 View Post
    Gotcha. Was just thinking once you run some real fuel and start trapping 140+ you might miss those 3.27s, was thinking of more power rather than the stumble.
    2014 M235i (wife's)
    1964 Ford F-100
    Jan 2008
    Jefferson
    4,674
    What's your tire size?
    Aug 2008
    duquesne
    544
    26.50
    -greco
    92 Coupe, 10.72@133
    Senior Member fox fan's Avatar
    Jan 2010
    Washington Pa
    235
    http://www.wallaceracing.com/gearcalc.php Not sure but this may help.
    Aug 2008
    duquesne
    544
    Been using wallace's calculator, 3.55's are what I need for current setup, putting the 3.73 and 4.10's back on the shelf for when I turn the boost up, thanks for all the feedback
    -greco
    92 Coupe, 10.72@133
  1. Replies: 16
    Last Post: 06-05-2013, 07:19 PM
  2. Name change
    By Seer in forum Site Announcements, Discussion & Help
    Last Post: 11-29-2011, 01:38 PM
  3. a little change
    By lib88stang in forum Fox-SN95
    Last Post: 09-11-2011, 09:21 AM
  4. Change????????
    By Gastrader1 in forum The Bar
    Last Post: 10-01-2008, 07:12 PM
  5. Speedo fix due to gear change
    By 04mustang232 in forum General Tech
    Last Post: 06-24-2007, 03:39 PM
