Thread: Torque box plates & rear suspension
    formerly Nsty98LS1
    Jun 2008
    Lilly, PA
    549
    I'm starting to plan the rear suspension of my car & was curious what makes the torque box plates vary so much in price? The Battle Box kit is $150 & looks no different than some of the other ones that I have seen. I'm not trying to cheap out on anything but I also don't want to pay more for something that does the same thing.
    I'm also looking at the Team Z adjustable LCA's & I'm not sure about what to use for the uppers. This car is going to be 95% street car. I'd like to hear some input on what to try & what not to try. I also do not want all polyurethane bushings in the rear suspension. I want the car to be able to hook hard when needed but be plenty streetable
    '13 IOM Camaro 2SS/RS: 3 pedals & needing a driver mod
    Aug 2008
    Washington Pa
    28
    I bought and installed upr torque boxes on both my fox bodies and have no complaints.
    Petersburg,PA. 16669
    816
    As long as the torque box kit has upper and lower plates and bolts i would just buy the cheapest one. I never saw a difference in ones i have seen. I would use upr/wild rides/ team z upper and lowers. I would use spherical bushings in the rear end itself also. By putting the plate kit in you wont tear up the upper boxes so i would just go with no polyeurathane at all.
    88 GT...and some boost
    i looked at multiple sets last weekend because i had the same questions umi has a little thicker material and more welds in corners , i just did these in my notch with a kit from late model resto the kit fit well but was not the thickest , but it was also one of the cheaper kits
    Aug 2008
    Washington Pa
    28
    Come to think of it I may have used umi on my coupe and upr on my gt. but in my opinion I could not tell a difference between the two sets.
    Senior Member celeste's Avatar
    Uniontown, PA
    276
    I have purchased and installed ones from Wild Rides (Battle Boxes) and from UMI and RNH performance. I had no complaints about any of them. UMI claims that they are the original designers and that everyone else has copied their design over the years. RNH peformance makes theirs out of stainless steel and I had found them through stangnet where Rick91GT is the owner of RNH. Bottom line, I do not think it would make a difference unless you are making some serious horsepower.
    http://www.fquick.com/celeste
    1989 Mustang GT 663 RWHP
    MM&FF May 2010 Cover/Feature Car AND 5.0 Magazine Oct. 2011 Feature Car
    1991 Strawberry Notch
    2003 Cobra White with Parchment inserts (1 of 170)
    1992 Calypso LX
    2008 Roush Blackjack #30 of 100
    MM&FF Article
    http://www.musclemustangfastfords.co..._gt/index.html
    5.0 Article
    http://www.mustang50magazine.com/fea...ble/index.html
    Member torqueboxer's Avatar
    white oak, pa
    638
    If yours aren't broke yet don't waste your money, remove the arms and weld every seam, they won't brake
  1. Ford 9inch torque specs & bearing preloads
    By JOlbert in forum General Tech
    Last Post: 01-02-2012, 10:56 AM
  2. Lower Torque box ?
    By Ares in forum General Tech
    Last Post: 04-26-2009, 01:09 PM
  3. roll bars-cages-front & rear suspension stuff
    By pudster in forum General Tech
    Last Post: 02-13-2009, 04:32 PM
  4. Torque Box Welds
    By Hawkeye in forum General Tech
    Last Post: 04-12-2008, 08:34 AM
  5. Torque Box reinforcement for foxes
    By 9002stang in forum Fox-SN95
    Last Post: 11-20-2006, 02:25 PM
