Results 1 to 8 of 8
Thread: anyone have an SIR airbag code reader?
    2.4 KB & Juice
    Export, PA
    844
    My 07 NBS silverado is throwing a "service airbag" on the DIC. A typical OBD2 scanner won't read airbag codes and I really don't want to pay the dealer BS fee's for a part I can buy for 1/2 the price and install myself. From what I understand, truck has 1 of 4 sensors that could be bad, wouldn't know which it is until I can get the exact code it's throwing. Anyone have a air bag code scanner? Obviously willing to drive to you, case of beer perhaps? Thx a bunch!
    Dan
    07 Silverado
    05 R6
    Brookline
    2,897
    Just to sweeten the deal, I will also contribute towards the use of one of these. My fiance's Tiburon just threw an AirBag code the other day.
    Mt.Pleasant pa 15666
    2,832
    I do,but its the one on bottom of rad support,if u have two there(1/2 ton trks) more then likely its the left one!
    2,832
    I do,but its the one on bottom of rad support,if u have two there(1/2 ton trks) more then likely its the left one! It may be the drem under drvers seat,have the dealer run ur vin # to see if its on the recall or bulletion list!
    2.4 KB & Juice
    Export, PA
    844
    Yes it's a half ton. I had that tsb done long time ago, the one regarding moisture build up. The two sensors by the rad are the same right? So if it's not one, I can swap ern
    Sent from my XT907 using Tapatalk 2
    07 Silverado
    05 R6
    2,832
    correct
    2.4 KB & Juice
    Export, PA
    844
    Thx a bunch!
    07 Silverado
    05 R6
    2.4 KB & Juice
    Export, PA
    844
    All fixed mater, was what you suggested, drivers side front sensor, Thx again!
    07 Silverado
    05 R6
  1. Loose Airbag
    By J-rod in forum Fox-SN95
    Last Post: 05-01-2014, 08:45 PM
  2. Airbag
    Last Post: 05-14-2009, 08:12 PM
  3. airbag light ?
    Last Post: 09-29-2008, 01:08 PM
  4. 90-93 column with airbag
    Last Post: 04-21-2008, 06:16 PM
  5. code reader
    By mattgt1000 in forum Fox-SN95
    Last Post: 06-17-2007, 09:52 PM
