Results 1 to 10 of 10
Thread: Electrical problem in Ranger.....HELP
    Senior Member Dan B.'s Avatar
    Armagh, PA
    4,331
    Took the Ranger to a small cruise this evening. Ran great on the way there and half way back. All of a sudden it started sputtering like it was running out of gas but I had plenty. Then it shut off. When you are reading and thinking, remember that this truck is very basic...it's a 1985, carbed, and all the added on accessories are ran through switches and relays that are powered when the key is on. Everything was dead....no lights, ignition, fans, nothing...thought the alternator was shot and battery ran dead. Called help and they came with a fresh battery.....still nothing. It has 12v to the hot post on the selonoid but that power is not going anywhere else. We grounded the hot post with a screwdriver against the mounting tab, it arched and all of a sudden everything came on. I hit the key and it started. I got to within one mile of home and it did it again. This time we tried isolating various circuits but nothing would work. Even took the battery lead directly to some of the accessories and nothing ran. Ground the battery lead and it sparks. I don't even have headlights that should work w/o needing to use the key.
    I'm puzzled.....help.
    Ahh fuque
    1986 Ranger--2WD, 5.0/T5/8.8.
    fairmont,WV
    1,352
    Double check all your grounds......sounds like one or more came loose.
    XXX RWHP
    XXX RWTQ
    If all your grounds are good, the solenoid could be fritzing or maybe a bad wire coming off the solenoid.
    Armagh, PA
    4,331
    Replaced selonoid this AM. That didn't do it. Have to put a starter on my F-150 first....then I'm going to dive into the Ranger.
    On a bright note....when I left the cruise I MAY have hammered on the 387W a little bit. It went through all three gears from a roll and the tires never did gain traction. ;)
    Ahh fuque
    Armagh, PA
    4,331
    Ranger is fixed. Turned out to be the main 12v feed from the selonoid around the engine bay to the fuse panel that is inside. There is a plug in the wire for seperating it if the harness needed pulled. Well that plug was melted in one end. It was actually fused inside and could not be pulled apart.
    Ahh fuque
    fairmont,WV
    1,352
    Good deal man....glad you fixed it.
    XXX RWHP
    XXX RWTQ
    Armagh, PA
    4,331
    I'm wondering what made the connection melt?? All of my add-on accessories are run on their own 12v source through relays. The switches come from the fuse panel on a switched 12v source but are energized by one miliamp.
    Ahh fuque
    Glad you figured it out Dan! Bring that beast down to the PVGP show on 7/20!!
    Somerset Co.
    2,907
    Payback for tar&chipping ;) lol
    Armagh, PA
    4,331
    Saturday is no good, maybe Sunday. I need to put some more miles on it before I venture into the big city. ;) It's easier to dodge traffic if something brakes on the small roads around here.
    Ahh fuque
  1. Need Electrical gurus help...charging problem.
    By 98saleen in forum General Tech
    Last Post: 11-03-2009, 10:15 AM
  2. Electrical Questions
    By Tony71502 in forum General Tech
    Last Post: 08-11-2009, 02:14 PM
  3. '89 Ranger No start problem
    Last Post: 04-03-2008, 11:52 PM
  4. Electrical Help.
    By Rio94gt in forum General Tech
    Last Post: 05-24-2007, 06:51 PM
  5. i have electrical problems too
    Last Post: 05-11-2007, 01:34 PM
