Thread: Rear sway bars
    I drive the Fairmont snailmont5oh's Avatar
    130
    Rear sway bars
    Hey,
    I'm looking for some swaybar options for the rear of my Fairmont. I currently have a bar from a 1986 Mustang GT. It is about 20mm. I'd like to try something about an inch (25mm), and maybe a 31mm bar from a '93 Cobra if anyone has one lying around. Any help would be appreciated.
    Thanks,
    Mike.
    Fairmonts are the same as a Mustang. I have suspension technique sway bars which are pretty beefy ( I think the rear is .9" and front is 1 3/8"). You could always bolt an adjustable Steeda rear sway bar (which is located above the rear end) on there while leaving the stock bar mounted in its original location.
    Throw a picture or two of your Fairmont on here. Most of us like them!
    Here is a picture of the additional Steeda bar installed!
    130
    It doesn't look like the Steeda bar will work with my Watts link. I'm hoping to find those sizes used so that I can tune without having to spend $150 per bar.
    I can do better than pics. Look at this. http://www.youtube.com/watch?v=ZKx9NqcDfog
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    Just get the Maximum bar and be done with it. But you still need to run more camber than you are running. You have a tiny front bar too. These cars will push sometimes when the bar is too small because of the body roll and shitty camber curve. Sometimes stiffening the front reduces push. I have a massive front bar, 1000lb springs in the stock location, 500lb in the rear, a maximum bar on the softest setting, and running 4.2 degrees negative camber in the front, caster maxed positive.
    Your 400lb front coilovers are fairly stiff for your rear springs as well. You mentioned to me the other day the understeer made itself known when swapping to the stiffer fronts. Those rears are great with a 1000lb stock location spring, or a ~300lb coilover. I don't think they are quite stiff enough for the 400s.
    2014 M235i (wife's)
    1964 Ford F-100
    you need more brakes before more sway bar
  1. 11-14 BMR rear sway bar new
    By whitesnake in forum Ford Vehicles
    Last Post: 09-28-2014, 09:25 PM
  2. Rear sway bar
    By TBone7281 in forum Ford Vehicles
    Last Post: 06-29-2012, 12:39 AM
  3. who needs front sway bars!!
    By 97LaserRed in forum Ford Vehicles
    Last Post: 11-01-2010, 09:33 PM
  4. Gt sway bars
    Last Post: 05-13-2009, 09:37 PM
  5. Rear Sway Bar
    By da9k1ne in forum Ford Parts
    Last Post: 01-07-2008, 04:01 PM
