Results 1 to 12 of 12
Thread: Sn95 t5 for fox t5
    Aug 2010
    washington,pa
    201
    Sn95 t5 for fox t5
    Looking to trade a sn95 t5 for a fox t5. I have the trans,bell housing, and shift fork. I need the same from a fox
    Wy not just use it in the fox? Input shaft is only slightly longer. The drive shaft will go in to the rear of the tranny far enough t put it all in the fox. Ran one in one of my foxes for years with zero issues. You can even use it with a fox bell housing. Just need to make up a spacer to go between the tyranny and bell housing.
    Aug 2010
    washington,pa
    201
    Could I grind the tip of the input shaft down some. Also what about the bearing retainer? I'm putting this in a ranger and just can't use the sn bell housing due to shift fork location difference than the fox
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    Just went through this. I know some have done it with success, but I wouldn't run the trans without shortening the DS.
    I had my aluminum DS shortened and balanced for $100.
    Or you could just swap fox inputs, and get a fox bell. I did that a few times back in the day.
    2014 M235i (wife's)
    1964 Ford F-100
    RRT juice_man_86's Avatar
    Uniontown, PA
    533
    x2 for swapping input shafts and bearing retainers
    Aug 2010
    washington,pa
    201
    K now I have to find an input shaft How hard are they to change
    Petersburg,PA. 16669
    816
    have to know what you are doing or all the needles will fall out but by doing this you cant use the sn95 bell
    88 GT...and some boost
    Aug 2010
    washington,pa
    201
    The sn95 t5 with bell housing and shift fork is up for sale. I found a fox t5 and be housing $300 obo
    Aug 2008
    duquesne
    544
    If I learned anything over the years do not buy a used t5 for cheap unless u get to test drive it first or see inside it, just my .02, I do have a fox bell here and will trade you if need be for your sn bell, I also have a fox input, but need to know which T5 you have first, either has needle bearings where it meets the main shaft, or has a caged roller bearing (world class t5)
    -greco
    92 Coupe, 10.72@133
    Aug 2010
    washington,pa
    201
    I really appreciate the offer. I got the fox set up and now just looking to sell the sn95
    Aug 2008
    duquesne
    544
    No problem what are you looking to get out of the sn95 stuff
    Sent from my SCH-I405 using Tapatalk 2
    -greco
    92 Coupe, 10.72@133
    Aug 2010
    washington,pa
    201
    250. That's what I paid for the fox stuff
  1. sn95 and fox performence parts
    By ERHsn95 in forum Ford Vehicles
    Last Post: 09-16-2014, 08:24 PM
  2. raceweight fox vs sn95
    Last Post: 07-14-2014, 09:45 AM
  3. New Kooks Fox/SN95 8.2 SS LT Headers
    Last Post: 10-12-2013, 01:20 PM
  4. Fox vs SN95 Transmission Crossmember?
    By 95DropTop in forum Fox-SN95
    Last Post: 11-04-2011, 06:00 AM
  5. fox guys who want sn95 seats
    By INSANELY CRAZY in forum Ford Vehicles
    Last Post: 03-31-2007, 06:46 PM
