Results 1 to 20 of 26
Thread: Getting close to hearing it run. My 1993 Calypso LX
    So I bought this car a few months ago and it was already torn apart by the owner before the owner I bought it off of. Needless to say that it was missing a few things.The kinda of build I am going for is just a very mild fun to drive every day if I have to car if I have to. It has a stock rebuilt t5 with a ram clutch kit. Stock rear end with stock gears(for now). The engine need a total rebuild. Someone had ripped it all apart cleaned a few things and put new gaskets and paint on it. It looked good but I would have never trusted it. Huge grind marks in the head gasket surface and intake/exhaust ports were the same. Looks like someone tried to clean the with a grinder as well as the piston tops. So now the engine I built is 306 with gt40p heads alex valve springs for a tfs1 cam, 3 angle valve job new guides and seals. Port matched exhaust and intake. Explorer upper and lower intake 70mm throttle body and egr spacer ported intake to 70mm. Under drive pullies with a/c and smog delete. 3g alternator 16" electric fan. Tapped thermostat housing for fan switch.
    I hope it runs ok. I would like to hear from people with simular builds.
    img.photobucket.com/albums/v638/mudbonestinkynutz/IMG_20130423_180138_994_zpsc88b62e0.jpg[/IMG]img.photobucket.com/albums/v638/mudbonestinkynutz/IMG_20130505_165228_566_zps354d42b6.jpg[/IMG]
    Car looks pretty clean. Good luck with the rest of the build and keep the updates coming!
    got it running yesterday. Sounds nasty with no exhaust other than an h pipe on it. It also need the o2 sensors. Couldnt let it run long only about 30 secs due to the fact I have no coolant for it either. Sucks being broke.
    Big member venom's Avatar
    North Fayette Township, PA
    1,344
    Getting close for sure man.
    2015 GTPP
    stuntman blksunshine88's Avatar
    Aug 2008
    duquesne
    544
    I love it! Super clean install on everything!
    -greco
    92 Coupe, 10.72@133
    Quote Originally Posted by blksunshine88 View Post
    Yeah everytime I do anything it try to make it look nice at the same time.Some times it takes twice as long but I get comments all the time on my work both at home and at my Job.
    Got coolant and my o2s lastnight gotta wire up my fan set the timing, idle, and tps than for a short trip to the gas station.
    Mt Pleasant, PA
    4,905
    That's a nice car, sat in my garage for a few years.
    Yeah this car was the nicest one I could find in my price range. I might complain about it but all the work is gonna be worth it. Also under neith the car last night I noticed at some time someone had reenforced the upper and lower control arm boxes. Just one less thing I have to do.
    Got this thing running pretty good now. I had a cylinder 6 misfire due to a bad injector so replaced them all with 24# and bigger maf for injectors. I am gonna need someone in the pittsbugh area who can do a tune for me any one have any recomendations?
    so.... now my clutch slips and have an oil leak in the bell area. How come I work on cars all day long and never have a problem untill its my own stuff?
    RRT juice_man_86's Avatar
    Uniontown, PA
    533
    sounds like rear main seal...also...most tuners like to use a maf set for stock injectors and tune the computer for the difference
    Senior Member 89 vert's Avatar
    plum
    487
    Looks real good! Hopefully the rear seal seals up. I had the exact same problem, I feel your frustration!!
    MSD ignition/King Cobra clutch/Polished Cobra upper and lower/Ported GT40p w RR/ 70mm tb/ 24 lb injectors/ pullies/ Mac cold air/ Mac long tubes/ H pipe/ 3:73 gears/ 3g alt/ welded sub frames/ Alum driveshaft/ CC plates/125 shot of juice/custom trunk/suspension goodies.
    FIRST PLACE 87-93 FOX BODY BUCKEYE STANGS SHOW 2010 AT SUMMIT RACING
    283 hp / 320 tq on mustang dyno (all motor)
    So where around this area can I get this thing tuned. And what else do I need
    Aug 2008
    duquesne
    544
    I would assume either wolfpack speed, or street lethal
    Sent from my SCH-I405 using Tapatalk 2
    -greco
    92 Coupe, 10.72@133
    I didn't think Wolfpack tunes pre-1996 Mustangs?
    Yeah I am not sure they do. Atleaset the didnt wann do my Maztang a few years ago. I am really just wondering if it is worth it.
    So my oil leak was the pan gasket at the rear super easy fix . Put in the Ram clutch kit and found my cylinder 6 misfire that turned out to be a defective spark plug. Thing runs good and sounds great except for a driveline vibration also that should be fixed when I get my aluminum drive shaft and do my gears and rearend rebuild. Also wanna make my charcoal canster system work again
    My drive line vibration ended up being some one installed the wrong u joint in the front. It was to small the caps fit and were sitting on the clips but the joint it self was to small letting the shaft move allover the place.
    Going to try and tackle the gears this week end never done them before. I hope it makes it eaiser to drive it has stock auto gears in it now. Pulling out with that high of a gear is kinda hard with the tfs1 cam
  1. 1993 foxbody fuel pump wont run
    By chuck94 in forum Fox-SN95
    Last Post: 06-10-2014, 01:05 PM
  2. 93 calypso lx
    By RAYZ02GT&93LX in forum Ford Vehicles
    Last Post: 08-25-2010, 10:42 PM
  3. 1993 calypso coupe turbo
    By fast4ord in forum Ford Vehicles
    Last Post: 08-04-2009, 09:56 PM
  4. calypso coupe
    By fast4ord in forum Pictures & Videos
    Last Post: 07-14-2009, 10:34 PM
  5. Replies: 6
    Last Post: 09-12-2006, 09:53 PM
