im gonna check it out tomorrow. but i wanted to get some opinions. 2009 mustang 26k miles. there is noise coming from what im gathering to be either the ball joint or the wheel bearing. the noise while it sounds to be something that happens as the wheel is turning im getting vibrations that i can feel in the wheel and the pedals while slowing. sounds like the bearing but today i was pulling out of a parking lot and i heard a pop. and when i pull into a lot from a left turn with my wheel to the left i hear a clunk. im not sure if that one is the same issue or just my bushing needing greased on my front sway bar. the vibrations feel like a warped rotor but arent as apparent until slowing from higher speeds just to kinda give you the feeling.
i know these parts shouldnt be failing this early which is why i have even less of a clue what the hell it is. hip hip hooray for construction zones and pittsburgh potholes...
