Results 1 to 11 of 11
Thread: 373 gears - what color speedo gear?
    OldB real_jeff's Avatar
    Belle Vernon Area
    45
    I'm going to have some 373's put in and I was wondering about the speedo gear I need to put in?
    Farmington WV
    4,672
    white 23 tooth.
    Quote Originally Posted by real_jeff View Post
    It really depends. Tire height and speedometer *drive* gear will dictate *driven* gear needed. What size tire (height) and what year is the trans?
    Junior Member Stangzrule's Avatar
    Connellsville, PA
    521
    Got a brand new white 23 tooth if that's what you need.
    Senior Member Cam99's Avatar
    Melcroft
    4,178
    I'm going to piggy back on this thread. 93 t-5 and 26" diameter tires. What is the diameter of stock size wheels on 16" pony wheels . 26" also?
    Belle Vernon Area
    45
    P225 16 or 25" Diameter. '95 GT 5 Speed.
    Member RUSH2112's Avatar
    Hopewell, PA
    754
    That's what I got with my 3.73 gears, white 23 tooth
    Stock wheels also. It's about 3-5 mph off
    The 225/55/16 tire diameter will vary somewhat depending on manufacturer. It's safe to say it will be close to 26" though.
    So we take the 26" tire height and multiply it by pi (3.1416) and arrive at circumference, that being 81.68". Then divide 63,360 (inches in one mile) by the circumference(81.68") to arrive at tire revolutions per mile. That value being 775.7 tire revolutions per mile.
    Then use this formula to calculate speedometer *driven* gear needed.
    Driven gear teeth= drive gear teeth x axle ratio x tire rev. per mile DIVIDED by 1000
    8 x 3.73 x 775.7 DIVIDED by 1000=23.14
    Looks like a 23 tooth speedometer gear would be the closest match.
    25" tire height = 78.54" circumference. 806.72 tire revolutions per mile. Now just plug those values into the formula:
    8 x 3.73 x 806.72=24072.525 DIVIDED by 1000=24.072
    23 tooth driven gear looks like the closest match in your application.
    As a side note: The 23 tooth driven gear is produced by a manufacturer other than FRPP. Due to the pitch of the teeth on that particular speedo gear abnormal/premature wear can occur because of the pitch differences.
    Belle Vernon Area
    45
    Yes, I need one.
  1. speedo gear
    Last Post: 01-26-2009, 10:14 PM
  2. Speedo Gear?
    By Stangman701 in forum General Tech
    Last Post: 10-06-2008, 11:21 PM
  3. any one need a t5 or rear with 373 gears
    Last Post: 04-08-2008, 10:42 PM
  4. 373 mototsport gears
    By urgonnaluz2me in forum Ford Vehicles
    Last Post: 05-23-2007, 11:19 PM
  5. 373 gears
    By chuck94 in forum Ford Vehicles
    Last Post: 05-19-2007, 02:41 PM
