Results 1 to 12 of 12
Thread: rocker arm question
    rocker arm question
    Does anyone have any experience or advice on using 1.7 ratio rockers with and e303 cam? I have read that changing the springs is a must and is a good idea to change out the push rods. Any info on this would be a great help.
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    What heads? I would definitely change the valve springs, but I would reuse the stock pushrods because I am pretty ghetto. Changing springs is much easier with the heads on than most make it out to be. I was able to do it just by bringing each cylinder to TDC, new valve seals help hold the valve closed when changing them, may as well do that while you are in there anyway.
    2014 M235i (wife's)
    1964 Ford F-100
    Stock heads currently otherwise stock valvetrain besides the cam. Forgot I had the rockers from another car I built a few years back. Been kicking around the idea of putting them on.
    Aug 2008
    duquesne
    544
    I ran stock heads a tfs stage 1 cam stock springs and pushrods for 35k + miles with no issues
    Sent from my SCH-I405 using Tapatalk 2
    -greco
    92 Coupe, 10.72@133
    Uniontown, PA
    276
    I put a b cam in my notch with factory heads and factory rockers and I put springs in. In fact, the car had 107,000 miles on it so I took the opportunity to do valve seals timing chain etc because I was in there. I read a lot of old school posts on corral and stangnet when the alphabet cams were popular and a big ticket item for foxes and most people complained of valve float at higher rpms without upgrading the stock springs so i was not about to take the chance. Whether there is any truth to that theory I don't know and I was not about to test the theory on my car.
    http://www.fquick.com/celeste
    1989 Mustang GT 663 RWHP
    1991 Strawberry Notch
    1992 Calypso LX
    MM&FF Article
    5.0 Article
    Petersburg,PA. 16669
    816
    Mark is right. I change springs with the heads on the same way. The trick flow kit is a nice upgrade and will be plenty enough spring. Stock exhaust valve floats @ .510
    88 GT...and some boost
    Aug 2008
    duquesne
    544
    X3 on changing springs with the heads on, any autoparts store sells, possibly rents, a tool to inflate the clyinder with air to eliminate the possibility of dropping a valve into the cylinder, (make sure both valves are closed before inflating with air)
    -greco
    92 Coupe, 10.72@133
    Thanks for all the help! Much appreciated!
    Trafford, Pa
    2,308
    Quote Originally Posted by blksunshine88 View Post
    But would you again now that you are much smarter? :)
    2014 M235i (wife's)
    1964 Ford F-100
    Aug 2008
    duquesne
    544
    Had nothing to do with smarts only budget
    -greco
    92 Coupe, 10.72@133
    Trafford, Pa
    2,308
    I really can't talk I bought one brake rotor today.
    2014 M235i (wife's)
    1964 Ford F-100
    Aug 2008
    duquesne
    544
    :banghead:
    -greco
    92 Coupe, 10.72@133
  1. rocker arm studs
    By pinkpony20000 in forum Ford Vehicles
    Last Post: 11-11-2012, 04:42 PM
  2. 4.6 rocker arm removal/install
    By gcode in forum SN95-New Edge
    Last Post: 09-01-2008, 08:16 PM
  3. control arm bushing question
    Last Post: 06-24-2008, 09:58 PM
  4. rocker covers
    By sweeney1030 in forum Ford Parts
    Last Post: 04-02-2007, 11:45 PM
