Results 1 to 7 of 7
Thread: McLeod St.Twin Clutch/Steel Flywheel
    South Hills, PA
    4,052
    Cool McLeod St.Twin Clutch/Steel Flywheel
    This clutch/flywheel is around $1200 new. It has around 3k miles on it. The scuff mark on the first pic was done from the clutch fork rubbed on the pressure plate for a few turns. nothing to be concerned with. The clutch grabs nice and smooth and it not jerky. McLeod advised me to set a .025-.030 air gap on the floater plate. i am including extra shims just incase it ever needs a reshim. all you need to do is unbolt the assembly and bolt is back together the way it came apart. there is paint marking on the flywheel, floater and pressure plate so they go back together correctly. The clutch is 26spline, 10.5" and has a removable 50oz weight on the back of the 157t flywheel. This clutch is rated for 1000+HP. I also have the directions needed for the install. I do not want to ship this and would like to sell it local so I will price it at a give away price.
    http://www.mcleodracing.com/products...l+Flywheel.mcl
    $325.00
    Thanks, Bill
    call or text,
    412-651-1920
    South Hills, PA
    4,052
    $300 picked up this weekend. Best deal out there !
    South Hills, PA
    4,052
    bump
    South Hills, PA
    4,052
    Last price drop . $275.00
    What a deal. I've already got one and I'm still considering it. Do you happen to know if it would bolt onto an 03 cobra flywheel?
    South Hills, PA
    4,052
    Not sure, I haven't messed with mod motors in a long time.
    South Hills, PA
    4,052
    Sold
  1. Replies: 0
    Last Post: 10-28-2014, 10:38 AM
  2. *used* 10.5" Ram Billet Steel Flywheel
    Last Post: 08-31-2013, 07:54 PM
  3. Mcleod rst twin disk clutch
    By HOTMARK7 in forum Ford Vehicles
    Last Post: 06-30-2013, 07:32 PM
  4. FRPP billet steel flywheel
    By frankstang in forum Ford Vehicles
    Last Post: 04-25-2013, 04:37 AM
  5. Tremec TKO,Mcleod shield and clutch
    Last Post: 09-05-2007, 04:12 AM
