This clutch/flywheel is around $1200 new. It has around 3k miles on it. The scuff mark on the first pic was done from the clutch fork rubbed on the pressure plate for a few turns. nothing to be concerned with. The clutch grabs nice and smooth and it not jerky. McLeod advised me to set a .025-.030 air gap on the floater plate. i am including extra shims just incase it ever needs a reshim. all you need to do is unbolt the assembly and bolt is back together the way it came apart. there is paint marking on the flywheel, floater and pressure plate so they go back together correctly. The clutch is 26spline, 10.5" and has a removable 50oz weight on the back of the 157t flywheel. This clutch is rated for 1000+HP. I also have the directions needed for the install. I do not want to ship this and would like to sell it local so I will price it at a give away price.
http://www.mcleodracing.com/products...l+Flywheel.mcl
$325.00
Thanks, Bill
call or text,
412-651-1920
