I pulled these off my '12 GT500 w/924 miles. They are in great condition. New $119.99 PM me if you have any questions. SOLD.
Details:
California Pony Cars NXT Generation Hood Strut Kit for 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Shelby GT500s, 2011, 2012, 2013 and 2014 V6 and GT Mustangs and 2012-2013 Boss 302 Mustangs.
This hood strut kit will eliminate your factory prop rod and dress up the engine bay. This kit is a simple bolt-on that requires no drilling! California Pony Cars manufactures high quality products that set the "Industry Standard" for quality, fit, form and function.
Hood struts make opening your hood much easier and safer. Once hood struts are installed, there is no need for that annoying prop rod that always gets in the way. Working under the hood will also be simpler as you won't have to maneuver around the hood prop. California Pony Cars' hood strut kit should be one of the first modifications on the way to a cleaner underhood area.
California Pony Cars created this kit for the basic mechanic. The kit simply bolts-on with no drilling or permanent modification required. A few bolts are loosened and removed to install the brackets and a windshield washer connection needs removed. Basic hand tools are needed for installation which means you can install the hood struts in your own garage or driveway.
Kit Includes:
- Pair of Two Gas Struts
- Pair of Upper Brackets
- Pair of Lower Brackets
- Installation Instructions
Color- OEM Black
