351 Cleveland,4bbl ported and polished heads,flat top pistons,solid cam. 850 carb.canton pan,msd dist,headman flat collector header,alum rad and electic fan,electric water pump drive.solid motor mounts. msd box. 8 point cage tied into frame connectors,race seats and belts,tach and shift light all gauges,nice battery box and flaming river battery shut off.upr uppers and liftbar lowers air bags and comp eng shocks.superior axles with long studs and a rear end girdle.full tubular front end and coil overs with caster camber plates.5spd trans with stage 3 clutch. welds with drag tires. fuel cell and electric pump.car is primered black and is ruff looking but a very solid and straight car. car had been sitting about 3 years just started and run up and down the road. not been raced in awhile. but I would think a good check over and go racing.call or text for faster response 8145053136 $5500.00
