Results 1 to 15 of 15
Thread: Lower intake porting
    Farmington WV
    4,672
    Any good shops around that can port a lower GT40 intake?
    I know Tmoss on Corral does it, but thought I would look a little more local before sending out west.
    I would just send it to tmoss he does a great job and knows just where to blend and open up that lower
    Polar Vortex
    6,031
    x2. Better off spending the extra 25-50 bux and its done right with no worries..
    Farmington WV
    4,672
    Tmoss is cheaper than the other two options I had been presented actually.
    It will all depend on what I do for heads. no since in porting the intake if it is mated to GT40P heads. If I get better heads then the porting will make a difference.
    it does help even with stock heads the intake is the restriction.
    I would send it some where other than tmoss. We had to send one intake back three times because the area he welded you could see a lot of light thru. The porting looked good but the welding wasn't good. It's unfortunate too because years ago he did something for my car and it looked good. But this one the weld wasn't even really "bonded" well. It didn't have any penetration and was very porous. Fox lake we have had great experiences with. There is another local guy I can send you to if you would like some one local.
    South Hills, PA
    4,052
    Greg @ TEA
    Member torqueboxer's Avatar
    white oak, pa
    638
    Why not sell the gt40 and take the porting money and get a better intake?
    Farmington WV
    4,672
    From what I found through online sources and reading, the GT40 flows very similar to the trick flow street I had looked at as well. I picked up a GT40 tubular upper/lower for a decent price. The TF outperforms the GT40 once over 5500 RPM and I do not expect this car to see a lot of that RPM range so the GT40 kind of worked.
    I had primarily considered porting if I got the Explorer intakes, but I spent a little more on the tubular GT40 instead. But depending on what I do for heads I may still go and have this lower ported as well...
    But all options are considered until I pull the motor lol
    What about Extrudehone porting?
    LA-TROBE
    178
    quadified racing engines ask for Bruno top notch guy
    7248750764
    highly highly recommended
    LA-TROBE
    178
    idk your situation also but are you planning on porting lower intake with stock heads>>?
    RRT juice_man_86's Avatar
    Uniontown, PA
    533
    It may not be the best flowing intake, but damn...the tubular GT40 sure is the sexiest looking intake.
    Farmington WV
    4,672
    Quote Originally Posted by 91gtlmstang View Post
    The plan was GT40P heads
    Quote Originally Posted by juice_man_86 View Post
    I agree. I am trying to find a GT40 351W lower. very tough to come by for a realistic price.
  1. PI Lower Intake for 4.6 SOHC
    Last Post: 09-19-2010, 09:46 PM
  2. WTB: 99-04 GT lower intake
    By Rio94gt in forum Ford Parts
    Last Post: 12-24-2008, 11:09 PM
  3. FS: 5.0L gt-40 intake ported lower
    By dappie99 in forum Ford Vehicles
    Last Post: 08-04-2008, 07:54 AM
  4. Porting Heads and Intake
    Last Post: 08-17-2007, 08:33 AM
  5. 87-93 lower intake versus SN95 lower intake
    By 95DropTop in forum Fox-SN95
    Last Post: 08-01-2007, 11:01 AM
