How much will a stock bottom end hold with a wetkit??? or better yet how big of a shot can i get it with once or twice ?
150 shot no problem. As long as tune is correct.:D
so a 200shot is out of the question to hit it once ?
i used to spray the crap out of my 92 GT with a 150 shot, i went through a bottle a week for like 2 years...
ok, i went to the track sunday with my GT, i ran 14.2. spinning in first, plus i got a back fuel pump im only getting 15-18psi at the rail. and ive been told its suppose to be 35-37. i looked at my plugs when i got home and they was whiteee, im thinking about going with that 255lph pump just in case for father mods or whatever, im hoping my car will run atleast 13.8 or so with tires and fixing the fuel prob. im not sure how much nitrous will give me
i was hoping to find a set of 16" et streets used, but there hard to find i gotta break down and buy new loll but i HOPE nitrous will throw me into high 12's
all i got right now is,full exhaust,underdrives,no smog or ac,cold air intake,heads shaved .30, Trick flow cam,1.7 rocker.
well most of you know my setup. stock motor with bolt-ons and 125shot this time and drag radials set at 13.5 psi.
1.44 60ft
7.21@92 mph
11.51@112mph
im running out of steam at 800ft. peak hp is 4000rpms and im trapping 6100rpms. i need to swap the 4.10's for some 3.73's i think
Yea, T-5 with ram clutch and steeda tri-ax.
The best advice I can give is select optimum gearing for combo, leave the line on the nitrous, and last but no least put a conservative tune in it, then inch up on it gradually.
The Car has 3:55's in it now, i know i should go lower, plus i was shifting at 6500
Not sure what TFS cam you got in there. But the stock intake is limiting peak rpm. I'd yank that f$cker about 1,000 rpm's less than you did last outing. That should put a little more MPH in it anyway.
