Thread: Show me your 94-95 5.0 with the Fox TB conversion
    Farmington WV
    4,672
    Fox TB Conversion to SN95
    I am most interested to see your N/A air intake solution when using the Fox TB.
    If you built one yourself and can share the specs/materials that be cool.
    I am leaning heavily to convert to the fox TB setup and am looking at the intake solutions.
    So share what ya can.
    new questions below.
    I did the fox swap on mine and the throttle response is greatly increased
    Farmington WV
    4,672
    I think if I can put together the swap for what I am expecting to pay for the Trick Flow intake elbow then I am going for it.
    I think I can piece together a good bit of it used and make it happen.
    I used all used parts on my swap , I like the egr delete plate from upr
    Farmington WV
    4,672
    Running into a brain fart here on the wiring of the TPS.
    Everything says to use the "fox pigtail" fuel injector side. Though when I look up the part for the pigtail of the TPS it shows the same for fox and SN95. So what I thought I would do is get a new pig tail from AAP and wire it up and do a plug n play as opposed to cutting up stock SN95 stuff.
    Here is what I have:
    The wiring on the new pig tail doesnt match the colors of OEM or write up I have been using:
    TPS wiring...
    SN95........TO...........FOX
    RED/GRAY..............BLACK
    GRAY/WHITE..........GREEN
    BROWN/WHITE........ORANGE
    I have come to realize that what I was bout to do was to make it a PITA to ever have to change the TPS. I want to find the fox TPS pigtail and wire into my new aftermarket pig tail so I can still plug in the TPS properly so I can replace as needed down the road.
    Anyone able to share what you did or what I am thinking wrong here?
    Farmington WV
    4,672
    Or come to think of it....are the aftermarket vendors listing the wrong pig tail for the fox and what I show is actually the sensor plug in for the SN95?
    Never mind. I realize it is the wrong pig tail.
  1. 84 fox body conversion please someone help
    By lawrence2012 in forum Fox-SN95
    Last Post: 06-09-2012, 12:28 PM
  2. Replies: 3
    Last Post: 12-28-2011, 11:11 AM
  3. Replies: 0
    Last Post: 03-13-2011, 07:01 PM
  4. Fox body 5 lug rear conversion $80
    By oldfox in forum Ford Vehicles
    Last Post: 09-24-2009, 02:31 PM
  5. WTB: Fox TB conversion parts ASAP
    By Rio94gt in forum Ford Parts
    Last Post: 03-27-2008, 02:19 PM
