13.565 at 104mph 2.00 60 foot time. Ran the Nitto Extremes 255/40/17s. I am sure the times would be better with some MT ET street radials.
2016 GT Premium
Congrats, with a little practice and seat time you will easily be in the mid 12's
General Douglas McArthur
Where did you run at? What are you shifting at? What was your 1/8th mile MPH and ET?
I ran at Quaker City - track rental day thru Cruizin Few car club. I was shifting at 5500rpm. I definetely need more practice - I missed the 1 to 2 shift and the 2 to 3 shift on 3 of my passes. Not sure if the synchros are gone or just my technique that is bad. The car felt like it was running out of power in 3rd gear at 2/3 track.
Here is my slip:
RT .715
60 2.000
330 5.779
1/8 8.799
MPH 82.90
1000 11.331
1/4 13.565
MPH 104.48
2016 GT Premium
I think your throttle body may be a little small for the heads, cam and especially the intake you are running.
Can you post a picture of your dyno graph? At what RPM did it make peak HP and TQ? There should definitely be more in it which is a good thing! :)
Why did it stop making power at 5200 rpms???
2016 GT Premium
That is a very low powerband, do you have your cam retarded?
Id figure whith your combo it would pull to 6000-6500 no problem. Somethings up, we just got to figure out what it is. Do you have an aftermarket ignition box? Problem could be there.....![]()
I am running the stock TFI ignition, stock distributor and stock 94 fuel rails. My tuner(Don Lasota) told me the stock stuff was good up to 500RWHP, so I kept them. Anyone know how to diagnose the ignition? Perhaps it is falling on its face. The car does have a problem restarting when it is hot. Sometimes I have to wait 10 minutes before it will restart.
Thanks for your input.
2016 GT Premium
cool
I had a similar problem wit my 86 gt. Changed the module on the distributor and problem solved... at least for me.
try holding the gas to the floor and see if it starts that wayi have to do that with my car during hot starts
