So I checked the voltage on my constant power wires, and either my gauge is tripping out, or it is reading a high 16 volts... with a 12v battery... that mean I have a short somewhere? I have 6 aftermarket gauges and they seem to be all wired into the same circuit. As soon as I connect the radio (aftermarket) and turn the key on, POP goes the fuse. I tried a different constant wire from under the glove box, same issue. I can however connect both the constant for the radio and the ACC for the radio on the ACC feed and the radio works fine and no fuse blows. I'm cornfused... LOL not the greatest with wiring other then radio type of stuff, but I've never had this problem. Oh an all grounds are good. I'm thinking a short? IDK.
Thanks!
