Results 1 to 19 of 19
Thread: 90 Notch Shell WIth new 25.5 Cage
Threaded View
    Bare 90 Notch shell that just recently had a MS 25.5 installed (ID Plate from the chassis shop on drivers down tube with serial number). Plated for BBF/Glide at a 1 inch offset. Wild Rides Lower Battle boxes installed and tied in. Double AA upper control arm cross member installed and tied in. Double AA caster/camber plates installed. Front frame from the strut towers foward is tubing and tied into the cage. Lower core support is tubing. All belt tabs installed. Window net supports installed. Mini tub installation started on right side - DMC mini tubs included, front sheetmetal and bumper $5250. Title in hand.
    or
    Including Kirky seat, Holcomb light weight aluminum steering column and wheel, Racecraft seat mount, Double AA Moly outlaw K-Member $5750.
    Pics soon.
    PM for contact info.
  1. fox shell on cl
    By somethingclever in forum The Bar
    Last Post: 07-18-2011, 12:35 PM
  2. FS:1990 mustang notch shell,from VA,no rust
    By 1badnotch in forum Ford Vehicles
    Last Post: 03-14-2010, 02:27 PM
  3. T/W 98 cobra shell
    By Jper in forum Ford Vehicles
    Last Post: 02-09-2009, 11:01 PM
  4. 73 fastback shell
    By madchaz in forum Ford Parts
    Last Post: 12-01-2008, 09:45 AM
  5. fox shell
    By 5k#Eaton in forum Ford Parts
    Last Post: 09-23-2007, 01:10 PM
