Results 1 to 6 of 6
Thread: WTB: Baer or Wilwood brake kit for 4-lug Fox Mustang
    I drive the Fairmont snailmont5oh's Avatar
    130
    I'm looking for a 4-lug aftermarket brake kit that will fit under 15"x7" 10-hole wheels, that is up to the task of open track. I got some Mustang spindles for my Fairmont, and I'd like something a little more heavy duty. If you took one off your car years ago, and you want it out of your garage, PM me or send me a text at 814-three two seven-9535.
    Thanks for the help.
    Mike.
    I have two rebuilt calipers for a 87-93 V8 Mustang with SVO 73MM pistons. Picked them up years before I did the Cobra brake conversion. I am not sure if Baer has a set up for a 4 lug 5.0?
    just step up to 13" 5 lug stuff for what you do they aren't even enough.. and then you can run 17" 05 and up wheels
    130
    And what fenders would I use to cover those up, Troy? Or should I say, what fenders would I have left after the car got crossed up once, and I turned the wheels to correct it? You of all people know that even the 225/45 16s try to remove the fenders sometimes.
    the 05 wheels pull them in a good bit and you might have to go up in spring rate to keep the fenders off the tires ??? and a nice low profile 17 could be same hieght as the 16s
    Mar 2009
    796
    These 2 SSBC kits are 4 lug SVO style track-prep brakes... $1600
    Front
    http://www.npdlink.com/store/product...8965-5983.html
    Rear
    http://www.npdlink.com/store/product...8944-5984.html
  1. 4 Lug Fox Brake System Parts
    By 50Dro in forum Ford Vehicles
    Last Post: 06-13-2012, 09:32 AM
  2. Replies: 0
    Last Post: 03-13-2011, 07:01 PM
  3. Replies: 0
    Last Post: 03-11-2011, 11:38 AM
  4. Wtb 5 lug axles (fox)
    By went9s in forum Ford Parts
    Last Post: 07-05-2010, 12:31 PM
  5. 14" Wilwood Brake Kit Install
    By thedak in forum General Tech
    Last Post: 05-24-2010, 12:21 PM
