Results 1 to 17 of 17
Thread: 1.5" Drop ok with sn95 rear in a fox.
    1.5" Drop ok with sn95 rear in a fox. Setup is 5 lug swap with 94 spindles pbr calipers. In the rear I used the sn95 axles and all other sn95 parts except the e-brake cables(used 1993 cobra ones). Sn95 master and stock booster. Using 17x8 bullitt wheels and 245/45/17 tires all the way around. Stops great now but the 4x4 look has to go. Didn't notice it much with the pony wheels but now with the bullitts it has to be lowered alittle. I Want to do a 1" to
    1.5" you think this will all work out.
    This image has been resized. Click this bar to view the full image.
    Mar 2009
    796
    Man that's a pretty LX!!
    Other than different offset rear wheels, there are also disc kits that restore the Fox rear track so you can keep your current wheels. I don't think you can lower it as is without rear fender rubbing.
    2,483
    Does a straight edge vertical on the tire contact the outer wheelwell lip? If so, you could either roll the lip under or use a cutoff wheel. If it doesnt hit the lip, lower away. Be sure to check inner clearances.
    Big member venom's Avatar
    North Fayette Township, PA
    1,344
    I used fox length axles and north racecar brackets when I did my swap. It kept my 10.5 wheels tucked in enough not too rub.
    Sent from my SCH-I545 using Tapatalk
    2015 GTPP
    After doing some looking I think I will be ok with no fender roll with my current size tire. I will keep everyone posted. Gonna order the springs and cc plates this week
    Mar 2009
    796
    After looking closer 1-1.5 might work because you have a lot of gap there.
    2,483
    might work for taking pictures, might rub driving.
    Member silvernotch's Avatar
    Bethel Park
    664
    I used sn stuff on mine with 99 cobra wheels and 245/17 tires. I rolled fenders because sometime it would rub. I have some new steeda lowering springs for sale
    Yeah that's what I was thinking too. I also wanna add the car already has steering rack limiters.
    Quote Originally Posted by silvernotch View Post
    pm sent on the springs
    Put my springs on yesterday. The car handles and looks much better. No rubbing and I was kinda pushing it.
    Before
    after
    Looks good...what springs did you use???
    I used the sr springs from american muscle they were on sale for 129.00. I am pretty happy with them ride pretty good for a performance spring.
    That's a good price...I'm gonna order some...thanx...
    Farmington WV
    4,672
    Looks really good.
    what shocks/struts you match the springs with?
    Quote Originally Posted by J-rod View Post
    Looks really good.
    just some kyb's
    I did the SN95 four wheel disc swap. I was going to tell you if you use the 17"x8" wide wheels you should be OK. I have 17"x9" wide Cobra Rs they will rub. I am
    rolling my quarters this spring.
  1. 9" Fox rear kit in Uniontown.
    By Donstang86 in forum Ford Vehicles
    Last Post: 07-27-2014, 10:56 AM
  2. Ford 9" rear in a fox body
    By roush08 in forum Fox-SN95
    Last Post: 01-19-2011, 09:21 AM
  3. WTB: Fox Drop
    Last Post: 03-26-2008, 12:10 AM
  4. Falken Lowering Springs 2" Drop
    Last Post: 08-28-2007, 10:24 PM
  5. Lowering Springs 2" Drop
    Last Post: 08-26-2007, 02:13 PM
