It wont be any of your sensors then. They would trigger a light. I would say fuel pump or fuel filter. Get a fuel pressure gauge and test that. A filter is easy to change. If it was your TPS, it would send a code for low voltage or high voltage. I, like colin, would lean toward a fuel delivery issue.
what would happen if you put in a larger pump and stock 19# injectors?
also i noticed my volt gauge seemed to be running low on the way home. i did have the radio,wipers,lights on....and its the stock 75a so maybe its normal...i turned the lights/wipers off and it climbed back up some. so i think thats normal...
i been thinking fuel anywyas.
i see LMM has 155 lph for sale same price advance has the stock ones.
just wonder if i should go pick it up or not.
LMM will work or even summit. I typicaly call Summit and haggle (they can see what I have purchased in the past ) Stay away from the big parts vendors that crap doesnt work - tried it before. Dont worry about going big, the system has a return, you will not run rich or anything like that. Differnt that a carb set up!
anyone wanna come down and help me do an install? :)
wick?
Its a pump. They go bad. Coral can tell you. He has the worst luck. Perhaps he and I can take a trip on Saturday. He is a whiz at doing them.
this thing any good.
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
I agree with jared dad bad or good in most cases check your fuel pressure before you buy anything.sounds to me like a bad plug wire. Maybe one got burt on the header.
