Results 1 to 7 of 7
Thread: How much horsepower would require a main support?
    I want to buld a mild street 302 for my 86 GT. Mild cam, nice heads, roller rockers, GT40 tubular intake. A little wild but nothin crazy. Engine is to be a STREETABLE CRUISER, 300-325 hp. What type of horsepower would you all think a main support would be needed?
    Hi Don - I don't think you need a girdle at that horsepower level. Many will argue that the only thing a girdle does is hold the pieces together when a motor lets go.
    Don - you know I'm miles away from knowing anything V8 related. That said ... Be honest with yourself on where a build will go. Is what you described going to keep you happy forever? Is your nature to evolve something over time (more power)?? That's likely where the answer lies. Not needed at the goals you describe, but I sure have learned to build a solid foundation to start because I keep changing stuff, lol.
    Talk about out scope creep, but I would question building a good 302 and not going 331/347 haha.
    RRT juice_man_86's Avatar
    Uniontown, PA
    533
    Keep an eye out for a Mexican block....go from there
    Sent from my Moto G
    2014 Mustang GT m6 - 12.97@111
    All stock down to the tires
    12.53 on slicks. Stock. No tune.
    1986 Mustang 5 speed - 12.10@110 off the sauce
    11.05 on Nitrous babying a hurt t-5
    327 stroker BOSS block with junk Pro Comp heads
    355hp n/a
    520hp on nitrous
    All Nitrous parts are gone. Turbo on the way
    Tuned by Tim @ Rodeheavers Hotrod & Dyno Shop
    Quote Originally Posted by PaxtonShelby View Post
    I agree. I wouldn't waste the money.
    1969 Camaro restomod/project
    1967 camaro
    2011 mustang procharged
    93 reef blue notch blk/int
    92 calypso notch blk/int
    86 t-type
    1972 chevelle project
    Not only did I fail at building a fast mustang but I bought a yellow zo6 cause I couldn't get my little dick up.
    Quote Originally Posted by Donstang86 View Post
    Don't worry about the main support. Honestly I have not seen them do any good. Same with a Mexican block. At the power level your wanting not necessary. I would have the assembly balanced and a proper tune done and it will live a long happy life.
    http://www.streetlethalperformance.net
    Let us know your parts needs! We will work to get you the lowest possible price!
    Member torqueboxer's Avatar
    white oak, pa
    638
    The main support will do a good job of holding the broken pieces together
    New combo going in 410w, tea225 high ports solid roller, novi2000, glens fuel system, pa
    Supercomp c4, some other things, hoping to run 10's...update 10.50@120 on 8 burned pistons...hoping to run 9's no cage in sight
  1. 4.6 horsepower add ons
    By 98gt in forum SN95-New Edge
    Last Post: 04-07-2012, 08:49 PM
  2. Starlite Horsepower night 8/19
    By map22 in forum Meets & Events
    Last Post: 08-17-2011, 12:41 PM
  3. Do all ATV's require PA plate and reg?
    By somethingclever in forum The Bar
    Last Post: 07-10-2008, 07:52 AM
  4. should i do a main support??
    By blkp42e in forum Fox-SN95
    Last Post: 01-24-2008, 08:50 PM
  5. what is horsepower? part 1 the equation
    By George C in forum General Tech
    Last Post: 11-11-2006, 12:59 PM
