Results 1 to 9 of 9
Thread: 363 dart v3 set up?? cooling issues
    LA-TROBE
    178
    hello was seeking out to any fellow members with
    similar setup that I run.
    iam having some cooling issues with the car !
    wondering if anyone has run into the same
    cars non intercooled
    idk if the rad fan set ups just poor or if the could be someother
    reasons!
    thanks justin
    mine is turbo but on pump gas it runs hot.Now on e85 its cool as hell.What type of fans do you have?
    LA-TROBE
    178
    mine is also pump gas motor and for fans 2-10ins
    I think I might pull it buy 4row rad 1 big single fan with shroud
    this is a street/strip car trying to turn it back into street car again
    Aug 2008
    duquesne
    544
    Make sure the fan is at least 3000cfm and you should be fine.
    -greco
    92 Coupe, 10.72@133
    LA-TROBE
    178
    Puller style?
    Mar 2009
    796
    Quote Originally Posted by 91gtlmstang View Post
    Some say a good thick 2 row aluminum radiator is better....
    2 rows with larger tubes give more cooling than 4 compact rows with small tubes.
    Mar 2009
    796
    Puller style?
    A puller is always best -- unless there is a space issue.
    I put a dual pass radiator in mine and a fan out of a contour wired on high speed that is the only fan i used that would cool it.
    LA-TROBE
    178
    Idk what brand rad but going run spal fan
  1. JE 363 Pistons
    By mlowry1260 in forum Ford Vehicles
    Last Post: 10-10-2010, 10:35 PM
  2. New 363/369 N/A Combo
    By gmkillr in forum Fox-SN95
    Last Post: 08-30-2010, 04:32 PM
  3. JE 363 Pistons
    Last Post: 01-08-2008, 09:36 PM
  4. dart 364 shortblock + more
    Last Post: 03-28-2007, 08:44 PM
  5. Dart shortblock for sale
    By Killercanary in forum Ford Vehicles
    Last Post: 03-14-2007, 11:55 AM
