Results 1 to 6 of 6
Thread: Does anybody know about soldering circuit boards
    1,220
    Does anybody know about soldering circuit boards or more de-soldering. I need to replace some capacitors. I can't seem to de-solder components. I have an old radio I am practicing on. I tried a solder sucker. That thing doesn't seem to work well at all on small globs of solder. I also have de-soldering braid, which seems to work, but not good enough. If I use the braid it looks like all the solder comes out, but there is still a little left and the component won't release. I really don't want to send this board out to get fixed over a 50 cent capacitor.
    Apr 2009
    Allison Park
    538
    Put the board in a vice, heat each side while pulling with a pair of needle nose pliers. Should pull out as soon as the solder melts all the way through. The solder sucker will remove 90% then it is alot easier to heat and pull the component. Practice, practice, practice makes it fairly easy to pull components.
    Randy
    Plum
    605
    Quick tip....add some fresh solder to the bead first to get it flowing, then use the braid or sucker to remove.
    93 GT, 408
    All Motor.
    Brookline
    2,897
    Both good tips ^^
    2013 Boss 302 #0082 unit5alive's Avatar
    May 2013
    Latrobe Pa
    41
    Thats what I do all day ! , how far away are you from latrobe?
    2013 Boss 302 #0082 , 24th produced in Race Red.
    1,220
    Quote Originally Posted by unit5alive View Post
    I live in Plum.
  1. Dee Zee aluminum running boards
    By PaxtonShelby in forum Ford Vehicles
    Last Post: 05-26-2011, 04:35 PM
  2. Anyone from the boards...
    By torchred v6 in forum The Bar
    Last Post: 09-30-2009, 06:22 PM
  3. F-150 Ford Running Boards
    By BoneCrusher in forum Ford Parts
    Last Post: 07-16-2009, 01:04 PM
  4. $200 circuit city cards
    By madmaxin22 in forum For Sale
    Last Post: 02-11-2008, 08:54 PM
