Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: Stang stuck at work...no start
    Farmington WV
    4,672
    so yesterday.....I think everything is normal and go out to get in the Stang and go home.....nope. not happening.
    it cranks and cranks but is either not getting spark or fuel.
    My fuel pump is powering up and seems to be working. pump supposed to be less than a year old. I tried to test the fuel pressure at schrader valve but the gauge they gave me is busted....so I was able to check the old way....pressed in the valve and turned key on and fuel shot out well....so should be good right?
    I pulled the vac hose off the FPR and did not have any fuel come out of the hose or squirt out of the FPR. did smell some fuel but I am sure that is normal from vapors.
    Am I missing something when it comes to the FPR? anything to test without the fuel psi gauge I can check in the morning?
    got spark coming out of the coil. Though had no spark at the end of plug wire.
    found and pulled the TFI Module. Took it to AAP and had it tested several times. They said it failed every time.
    I had AAP order me an Accel TFI module and it will be in tomorrow. Anything wrong with the Accel TFI?
    Just odd to have happened immediately with no warning.
    Polar Vortex
    6,031
    If you have fuel at the Schrader valve you should be getting fuel to your injectors....
    Farmington WV
    4,672
    My thoughts exactly.
    how common is it for a TFI to fail on the 94-95 models?
    i know I have spark at the ignition coil. But nothing at the plug wires to plugs
    State College, PA
    3,552
    Quote Originally Posted by J-rod View Post
    Its actually somewhat common, and a bad one will cause just what you're describing. pop in the new one and you should (hopefully) be good to go. Some people actually relocate theirs because I think the heat is what kills them. At least in the fox bodys people relocate them cause they're attached right to the distributor, not sure where they are on the 94/95s. I know the coil is in a different spot...
    2013 Mustang GT
    1999 Contour SVT
    Farmington WV
    4,672
    The 94-95 TFI is located in a heat sink on the passenger side fender under the air intake.
    Polar Vortex
    6,031
    I agree with this plus it does the old one minute it works and the next it's done. No warning.
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    They go bad all the time.
    2014 M235i (wife's)
    1964 Ford F-100
    RRT juice_man_86's Avatar
    Uniontown, PA
    533
    Not sure about the 94-95's but the ones in the distributor actually had a recall on them.
    Sent from my Moto G
    All stock down to the tires
    355hp n/a
    520hp on nitrous
    Farmington WV
    4,672
    I am almost certain it is spark related. As in not getting spark past the ignition coil. Hopefully get back in town this evening and pick up the TFI and hopefully fire up the stang
    Aug 2008
    duquesne
    544
    Either the module on the fender well, or the pickup in the distributor took a poop.
    -greco
    92 Coupe, 10.72@133
    Farmington WV
    4,672
    it is starting.....running.....and home.
    Though the $50 wasted on the TFI could have done without. AAP tested it and "failed" every time. put in a new one and still no start.
    Ironically/Sadly it ended up being cap/rotor. what I should have started with in the beginning. Oh well....$75 later she is home and running ok.
    time for plugs and wires now to complete it LOL
    Thanks for all the suggestions and thoughts here.
    Glad you got it sorted out and home safe.
    Farmington WV
    4,672
    I spoke too soon. it started several times yesterday evening....drove 30 miles home. all good.
    get up this morning to go to work and no start.
    So I left its butt at home and drove my Jeep LOL
    May 2008
    Hampton
    544
    Could it be moisture related? Was it wet the first time it quit?
    Polar Vortex
    6,031
    Did you end up putting the new TFI module on or the old one?
    Farmington WV
    4,672
    Quote Originally Posted by gpfarrell View Post
    no. first time it quit was a nice warm day. then it was in a garage for a couple days so shouldnt be a moisture issue.
    looks like I gonna try the pickup this weekend weather permitting
    Farmington WV
    4,672
    The new one. I plan to pull it off and have AAP test it too. from what I am gathering they all test bad on their machine....
    I kept the OEM one
    Farmington WV
    4,672
    should the pickup throw a code if faulty?
    Uniontown, PA
    533
    Almost nothing throws a code on these old mustangs lol
    Sent from my Moto G
    355hp n/a
    520hp on nitrous
    Farmington WV
    4,672
    I have heard the tach should jump a little when the coil is supplied power with the key on. Mine does not move at all. could the coil have enough spark when jumped at the coil but not enough when connected and try to start?
    When I removed the coil wire off the coil itself and jumpered it I had spark. When I tried to jumper it from the other end of the plug wire (end went on cap) I had no spark.
    could the spark be too weak?
  1. Stang wont start
    By ruger77 in forum Fox-SN95
    Last Post: 06-18-2010, 10:35 PM
  2. Stuck Valve
    Last Post: 10-13-2009, 04:19 PM
  3. distributor bolt stuck?
    Last Post: 07-21-2009, 03:36 PM
  4. Another start to a project to the stang
    By wick in forum General Tech
    Last Post: 04-27-2008, 12:17 PM
  5. Accellerator stuck
    By 03 OW SVT in forum The Bar
    Last Post: 03-21-2007, 06:07 PM
