Results 21 to 40 of 42
Thread: Stang stuck at work...no start
  1. #21
    Farmington WV
    4,672
    coil replacement did nothing.
    Any way to test a pickup or just replace and hope?
  2. #22
    Senior Member Dan B.'s Avatar
    Armagh, PA
    4,331
    Electrical problems suck.
    Ahh fuque
    1986 Ranger--2WD, 5.0/T5/8.8.
  3. #23
    Member Red98GT's Avatar
    Sep 2007
    Uniontown, PA
    64
    Mine was cranking and cranking but would not start. Ended up being the computer. My fuel pump wasn't working, I tried changing that first and then my buddy tried a spare computer he had. It started but idled funny, the tps censor was reading voltage off of the ground. Ended up being that his other computer was bad also bc we tried another one and it was fine. So I ordered a new one. Not sure about yours but thought I would let you know about mine.
    98 Mustang GT
    P1sc, 4:10's, PI Intake, alum. Dr. Shaft, Eibach Springs, Steeda Tri Ax, Bassani X Pipe, Bassani Cat-Back
  4. #24
    Farmington WV
    4,672
    that they do! lol
  5. #25
    Farmington WV
    4,672
    ok so.....should the tach jump or not when the ignition is turned to on but not cranking? or should it only jump when cranking?
    I am trying to find a dizzy to borrow and see if it fixes but I only know one local person with an SN 5.0
  6. #26
    Senior Member TJH64's Avatar
    Delmont PA
    320
    Right before I dropped the stroker in, I was having the exact same problem with mine. Replaced TFI module, coil, rebuilt the stock distributor....nothing seemed to work. I don't recall how or why I decided to look into the engine coolant temp sensor symptoms, but what I found seemed to mirror the problems of my car. So I replaced the sensor, which was about 15 bux, and no more issues. Thought I would share my experience, hope it works out for you.
  7. #27
    Farmington WV
    4,672
    really? I would not have guessed that at all.
    did you have a CEL code for a coolant temp sensor? I have pulled codes twice and I hahve no codes.
  8. #28
    Delmont PA
    320
    Quote Originally Posted by J-rod View Post
    No, I had zero codes. That is what made it so frustrating.
  9. #29
    Farmington WV
    4,672
    just ordered a reman dizzy with new pickup installed. gonna try it and see what happens.
  10. #30
    RRT juice_man_86's Avatar
    Uniontown, PA
    533
    I had a 79 Datsun 280zx that a bad coolant sensor caused that same problem
  11. #31
    Farmington WV
    4,672
    The coolant temp sensor would not prohibit spark to the plugs though would it?
  12. #32
    2,483
    If the coil was good at the head, but once the wire attached it didn't spark on the dizzy side, I would have replaced the coil wire first.
  13. #33
    Farmington WV
    4,672
    I did that previously.
    Though I only hooked it right to the dizzy. Not check for spark as I was alone and had nobody to crank for me.
    it didn't fire when the wire was replaced
  14. #34
    2,483
    Turn key to run and jump solenoid with a insulated screwdriver.
  15. #35
    Delmont PA
    320
    Quote Originally Posted by j-rod View Post
    the coolant temp sensor would not prohibit spark to the plugs though would it?
    yes!!
  16. #36
    2,483
    I could see it messing with the fuel for a/f ratio, but spark?
  17. #37
    Farmington WV
    4,672
    Quote Originally Posted by Silverhatch View Post
    would be a ton easier if the 94 had an engine bay mounted starter solenoid. LOL. Will pick up a remote starter switch and give it a shot.
    Thanks!
  18. #38
    State College, PA
    3,552
    yes!!
    I don't believe this is correct^ .... the coolant temp sensor is used by the computer to adjust A/F ratio. Even if the sensor is completely unplugged, the car should still run as the computer uses default values in case the sensor is faulty or unplugged. shouldn't affect cranking spark at all
    2013 Mustang GT
    1999 Contour SVT
  19. #39
    Uniontown, PA
    533
    So unplug it and see if it starts
    Sent from my Moto G
    All stock down to the tires
    355hp n/a
    520hp on nitrous
  20. #40
    Farmington WV
    4,672
    Had a few minutes between work and practice today so I got the ignition tester out.
    For sure:
    spark at ignition coil
    spark through ignition coil to cap
    no spark at spark plug wire end
    going to pull the advance auto TFI on Saturday morning and have it tested along side the oem unit they originally said was bad while I wait on my dizzy from rockauto
  1. Stang wont start
    By ruger77 in forum Fox-SN95
    Last Post: 06-18-2010, 10:35 PM
  2. Stuck Valve
    Last Post: 10-13-2009, 04:19 PM
  3. distributor bolt stuck?
    Last Post: 07-21-2009, 03:36 PM
  4. Another start to a project to the stang
    By wick in forum General Tech
    Last Post: 04-27-2008, 12:17 PM
  5. Accellerator stuck
    By 03 OW SVT in forum The Bar
    Last Post: 03-21-2007, 06:07 PM
