coil replacement did nothing.
Any way to test a pickup or just replace and hope?
Mine was cranking and cranking but would not start. Ended up being the computer. My fuel pump wasn't working, I tried changing that first and then my buddy tried a spare computer he had. It started but idled funny, the tps censor was reading voltage off of the ground. Ended up being that his other computer was bad also bc we tried another one and it was fine. So I ordered a new one. Not sure about yours but thought I would let you know about mine.
98 Mustang GT
P1sc, 4:10's, PI Intake, alum. Dr. Shaft, Eibach Springs, Steeda Tri Ax, Bassani X Pipe, Bassani Cat-Back
ok so.....should the tach jump or not when the ignition is turned to on but not cranking? or should it only jump when cranking?
I am trying to find a dizzy to borrow and see if it fixes but I only know one local person with an SN 5.0
Right before I dropped the stroker in, I was having the exact same problem with mine. Replaced TFI module, coil, rebuilt the stock distributor....nothing seemed to work. I don't recall how or why I decided to look into the engine coolant temp sensor symptoms, but what I found seemed to mirror the problems of my car. So I replaced the sensor, which was about 15 bux, and no more issues. Thought I would share my experience, hope it works out for you.
Fordstrokers 347 4.030 bore, 3.400 stroke, 5.315 rod, 10.6:1CR
Canfield 195 heads, Ferrea 6000 valves, Comp springs, Ti retainers, roller rockers, hand bowl blended
Camshaft Innovations custom billet core hydraulic roller camshaft
TFS Track Heat, 75mm TB, 90mm MAF, 36lb/hr inj
TREMEC 3550, billet flywheel, RAM clutch, 4.10 gears
really? I would not have guessed that at all.
did you have a CEL code for a coolant temp sensor? I have pulled codes twice and I hahve no codes.
just ordered a reman dizzy with new pickup installed. gonna try it and see what happens.
I had a 79 Datsun 280zx that a bad coolant sensor caused that same problem
The coolant temp sensor would not prohibit spark to the plugs though would it?
If the coil was good at the head, but once the wire attached it didn't spark on the dizzy side, I would have replaced the coil wire first.
I did that previously.
Though I only hooked it right to the dizzy. Not check for spark as I was alone and had nobody to crank for me.
it didn't fire when the wire was replaced
I could see it messing with the fuel for a/f ratio, but spark?
I don't believe this is correct^ .... the coolant temp sensor is used by the computer to adjust A/F ratio. Even if the sensor is completely unplugged, the car should still run as the computer uses default values in case the sensor is faulty or unplugged. shouldn't affect cranking spark at all
2013 Mustang GT
1987 Mustang GT
1999 Contour SVT
So unplug it and see if it starts
Sent from my Moto G
2014 Mustang GT m6 - 12.97@111
All stock down to the tires
12.53 on slicks. Stock. No tune.
1986 Mustang 5 speed - 12.10@110 off the sauce
11.05 on Nitrous babying a hurt t-5
327 stroker BOSS block with junk Pro Comp heads
355hp n/a
520hp on nitrous
All Nitrous parts are gone. Turbo on the way
Tuned by Tim @ Rodeheavers Hotrod & Dyno Shop
Had a few minutes between work and practice today so I got the ignition tester out.
For sure:
spark at ignition coil
spark through ignition coil to cap
no spark at spark plug wire end
going to pull the advance auto TFI on Saturday morning and have it tested along side the oem unit they originally said was bad while I wait on my dizzy from rockauto
