Results 1 to 19 of 19
Thread: Roaring sound on my 05 lincoln aviator
    Feb 2011
    105
    i have a 05 lincoln aviator and its been makeing a high roaring sound when i start it and and go. i was told it was the clutch fan and i replaced it with a ford and a after market one and still haveing same roaring sound anyone have this issue with same or somewhat same car thanks
    State College, PA
    3,552
    where does it sound like its coming from? does it change with rpms?
    2013 Mustang GT
    1999 Contour SVT
    Feb 2011
    105
    the sound is coming from that fan
    2,483
    Does it sound like its running on high for about 5 minutes?, then ramps down?
    Feb 2011
    105
    no the temp stays normal
    Castle Shannon
    1,276
    they are vicious and do fail, fan clutch stuck on my toyota pickup and sounded like a jet engine.. good thing is they are generally pretty cheap and cake to change
    Feb 2011
    105
    i replaced with a ford one and also a after market and still the roaring still the same
    2,483
    I meant the fan rpm.
    Feb 2011
    105
    no it stays the same
    Bad temp sender causing it to run on high?
    Feb 2011
    105
    that would make the roaring sound like the clutch fan is bad ?
    RRT juice_man_86's Avatar
    Uniontown, PA
    533
    Just to clear things up....their is a fan that bolts to a clutch that bolts to the water pump.....which did you replace
    Sent from my Moto G
    All stock down to the tires
    355hp n/a
    520hp on nitrous
    Feb 2011
    105
    the clutch fan that bolts to the fan
    Any chance something else in that area is making the noise? Bad belt tensioner...alternator bearing...really hard to tell without being there...
    Uniontown, PA
    533
    Water pump...power steering pump...running out of possibilities
    Sent from my Moto G
    355hp n/a
    520hp on nitrous
    Feb 2011
    105
    I took off the fan and clutch completely and it was quite and when I put it back together it was roaring again
    Water pump ready to crap out???
    Feb 2011
    105
    I can I tell or r u saying that's the prob?
    That's just a suggestion. Seems like the fan is not the problem because you already replaced the clutch and nothing changed.
  1. Surround Sound System
    By torchred v6 in forum For Sale
    Last Post: 12-07-2010, 05:32 PM
  2. Sound Racer V8
    By Chargin2004GT in forum Pictures & Videos
    Last Post: 02-13-2010, 01:43 PM
  3. what mufflers sound best?
    By Johnny B in forum General Tech
    Last Post: 01-31-2009, 12:05 AM
  4. Sound
    By Mr. Rob in forum The Bar
    Last Post: 09-09-2007, 02:27 PM
  5. this might sound stupid
    By Rodeheaver's in forum The Bar
    Last Post: 01-08-2007, 08:06 AM
