Results 1 to 5 of 5
Thread: Ford Motorsport 5300-B springs / Koni shocks installed - why not level ?
    Jul 2010
    North Huntingdon, PA
    438
    I recently installed a new set of Ford Motorsport 5300-B lowering springs, Koni shocks and struts and new spring isolators on a '93 notchback. When I initially did the springs and isolators, the car sat lower in the front similar style to the old muscle car look. I drove the car for about 100 miles to make sure everything was seated properly and still had the "rake" look. After installing the Koni struts and shocks and driving the car for another 100 miles, the "rake" is the same. I would guess right now the rear is sitting about 1.5" higher than the front. I see that the Motorsport C springs for convertibles have a larger drop in the rear than the B springs do. Is this common with the B springs to end up with a "rake" look front to rear ? Suggestions to correct the problem ?
    Member torqueboxer's Avatar
    white oak, pa
    638
    Rotate the rear springs to put the open part forward on the lca. And remove the isolators that's good for 1/4-1/2 inch
    Jul 2010
    438
    Is it common to end up with a "rake" look with Motorsport springs ? Are other companies better with leveling everything out ?
    white oak, pa
    638
    It has more to do with how they are rotated and tinkering with the isolators
    Jul 2010
    438
    OK thanks. I'll try to rotate them this weekend and see how it looks.
  1. Fox Springs and Shocks.
    Last Post: 08-29-2012, 10:29 PM
  2. Rear Shocks- Bilstein HD vs Koni STR.T and Koni Sport
    By Tommy079 in forum General Tech
    Last Post: 05-17-2011, 04:06 PM
  3. Just installed my lowering springs
    By Black02GT in forum Pictures & Videos
    Last Post: 06-04-2010, 12:44 PM
  4. Ford Motorsport "C" Springs NEW in box
    By Donstang86 in forum Ford Vehicles
    Last Post: 06-02-2010, 07:22 AM
  5. KONI Quad Shocks 25-1215
    Last Post: 03-10-2008, 09:08 PM
