So if I am translating the beeps as seen in the video I shot...I have the following codes?
81 Secondary Air Diverter Circuit Failure (O)
82 Secondary Air Bypass Circuit Failure (O
14 Profile Ignition Pickup Circuit Failure (CM)
18 Spark Out (SPOUT) Circuit Open (R), Loss Of Ignition Diagnostic Module Input To PCM/SPOUT Circuit Grounded (CM)
29 Insufficient Input From Vehicle Speed Sensor -To 1992 (CM), Insufficient Input From Programmable Speedometer/Odometer Module -From 1993 (CM
41 System Indicates Lean -passenger side(R), No o2 Sensor Switching Detected. always lean -passenger side(CM)
91 o2 Sensor Circuit Indicates Lean -driver side(R), No o2 Sensor Switching Detected. always lean -driver side(CM), Shift Solenoid 1 Circuit Failure (O)
If this is correct, are there any particular codes that should cause alarm or that would affect performance? I am assuming 18 was when I adjusted my timing and had spout off.
