I purchase some 15x4.5 billet along with a 1"spacer along with some studs that were machine pressed into the spacer. As i installed the wheel the factory hub are a bit too long an are rubbing against the spacer, i cute the factory hub stubs until it was flush with the spacer. Within the next 2 days my driver side hub bearing when out, my friend said the wheel is putting to pressure on the wheel hub thats why is went bad. is that true? Can some one who have a 03 cobra mustang with 15x4.5 in the front tell me how you'll installed it...
Thanks.
