Results 1 to 8 of 8
Thread: 1993 foxbody fuel pump wont run
    817
    fuel pump wont run unless i jump it then runs constant with key on shouldnt it prime then kick off any help appreciated also tried start jumping relay still wont run also put no relay any ideas computer possibly??
    Petersburg,PA. 16669
    816
    Check relay under the hood by air meter and relay by computer
    88 GT...and some boost
    Zoom50
    Dec 2013
    Tarentum
    97
    I'm assuming you checked the emergency fuel shutoff switch? There is a inertia switch that cuts the fuel off in case the car is in a collision, but this sometimes trips from bumps, etc. On the fox body verts, it is located in the left fender well inside the trunk. It is a small box with a button on top, depress the button & the fuel flow should reactivate. On the fox coups it is located elsewhere on the rear quarter panel inside the car, behind the drivers seat.
    On my 88GT hatch the inertia switch was inside the driver's rear of the taillight panel, and my fuel pump relay was underneath the driver's seat.
    Uniontown, PA
    276
    Late 92-93 relay is on passenger side under MAF. Older cars were under drivers seat. They are two different relays between those years too. If you want to test it, there is another relay next to the fuel relay under the MAF and they are identical. The other one is for the inertia (I think). Just swap them around and it should run the pump if that is the problem and assuming the other relay is correct. Have tested that way before and found the problem. Hope that helps.
    http://www.fquick.com/celeste
    1989 Mustang GT 663 RWHP
    1991 Strawberry Notch
    1992 Calypso LX
    MM&FF Article
    5.0 Article
    817
    I need a computer someone stole mine no wonder won't run
    817
    Long story short car was in my garage I sold supercharger and other parts I left a older guy finish takin T. Rex pump and msd boost control and box why I had leave for me to find out he stole my computer ****ed up can't trust anyone alone now days
    Holy cow - that's unreal.
  1. boost a pump and cobra fuel hat with pump .
    Last Post: 07-16-2014, 09:17 PM
  2. Replies: 25
    Last Post: 09-11-2013, 05:29 PM
  3. Top Fuel Dragster Fuel Pump Demo single cylinder
    By speedracer in forum Pictures & Videos
    Last Post: 08-27-2011, 01:54 PM
  4. what fuel setup should I run
    By boost_92 in forum SN95-New Edge
    Last Post: 08-21-2009, 12:12 AM
  5. Fuel tank & 255lph fuel pump Pics inside
    Last Post: 07-18-2009, 12:14 PM
