Results 1 to 5 of 5
Thread: Coilovers, can you identify these
    Member madmaxin22's Avatar
    on the red belt
    853
    someone owes me some cash and wants to give me these qa1's... these are coilovers right? does anyone know what model they are or what they fit or what they are?? also has two coil springs, supposidly everything is new
    2014 RAM QUAD CAB 8SPD
    Fairly certain that all of their shocks and struts have the bodies threaded to be used as a coil over application, but see no reason you could not just use them as a regular shock if desired.
    Sent from my iPad using Tapatalk
    Member torqueboxer's Avatar
    white oak, pa
    638
    Those are for a backhalf car(ladderbar or 4 link) not any type of mustang situation
    RRT juice_man_86's Avatar
    Uniontown, PA
    533
    Could be used with stock style control arms if you decided to mini tub your car. Mounting tabs and a crossbar would be required
    Sent from my Moto G
    All stock down to the tires
    355hp n/a
    520hp on nitrous
    on the red belt
    853
    thanks guys... tell him im not interested
  1. Identify this clutch
    Last Post: 05-18-2011, 11:17 AM
  2. can someone identify this part
    Last Post: 03-01-2010, 08:17 PM
  3. Coilovers..
    Last Post: 01-21-2010, 06:10 PM
  4. how to identify 2.3 vs 2.5 ranger motor?
    Last Post: 08-03-2008, 05:01 PM
  5. help me identify this FPR
    By White5.0 in forum Fox-SN95
    Last Post: 07-27-2008, 03:10 PM
