Results 1 to 9 of 9
Thread: hot exhaust
Hybrid View
    hot exhaust
    i have an 88 gt 5.0 and recently put another auto. tranny in it.when i put my exhaust back up and fired it up within minutes my top cat was glowing cherry red i was told it could possibly be the oxygen sens.can anyone help with my problem?
    Pittsburgh, Pa
    459
    A convertor "glows" when it is full of fuel, or it has simply glogged itself with hydrocarbons (basically fuel but in simple form). How was your car running? Was it "missing". Did you drip any ATF into the exhaust during your trans swap? ATF=fuel in this case. It could be an O2 pegged lean and making the car run rich, but i wouldnt jump to that just yet.
    right now the car has very little power .no i had the exhaust off and set aside before dropping the tranny.i also thought the exh. may be plgged up but at the tailpipe it seems to have flow
    Pittsburgh, Pa
    459
    car has very little power?? as in it wont rev-up? foot to the floor...what happens??
    car revs-up but without exhaust it seemed to have more power now with exhaust it will barely break the tires loose and sort of has a missing shudder.
    Farmington WV
    4,672
    still seems to me like a clogged cat.
    shaler,pa
    1,010
    Yes this is the correct reason. maybe to much fuel pressure.
    Pittsburgh, Pa
    459
    kinda sounds like that to me too.
    Gibsonia PA
    413
    yea sounds like its runnin way to ritch or is misfiring and burned up your cat. id check the fuel pressure, if it seemes to be runnin smooth. and replace the H pipe once you figurte out what caused it
    00 Yamaha V Star 1100
    88 Ford F250
  1. That's Hot
    By Minstang in forum Pictures & Videos
    Last Post: 04-03-2009, 11:35 PM
  2. looking for a 5.4 or hot 4.6
    By low12lightning in forum SN95-New Edge
    Last Post: 04-02-2007, 09:44 PM
  3. Rice world finals + hot new exhaust styles
    By stangr6man in forum Pictures & Videos
    Last Post: 03-17-2007, 03:42 PM
  4. Replies: 9
    Last Post: 11-18-2006, 11:29 AM
  5. Too Hot
    By burntire in forum The Bar
    Last Post: 10-28-2006, 12:42 AM
