Results 1 to 19 of 19
Thread: AOD Fox- Are they that lame?
    Zoom50
    Dec 2013
    Tarentum
    97
    I am regretting my decision to purchase my 91 stang last fall after tonight. before I go on, here are the mods:
    1. New 306 crate w/ <3k miles
    2. GT40P heads
    3. Ford Motorsport headers
    4. Off road H pipe, FM mufflers
    5. 24lb injectors
    6. AOD (yea...sucks ass) with PA valve body
    7. MSD ignition
    8. E303 cam
    So I could not even break traction today... Give me a f'n break. My old 5 speed 87 5.0 with basic bolt-ons and 200K miles would smoke this car. I can't figure out why the acceleration is so unimpressive. Is the AOD that lame? I have dumped tons of money trying to make this stang feel like my old '87 with more goodies and no luck. Before I dump more money into this good looking car, I wan't to bitch and see if anyone has suggestions. Maybe its just me...Would love for another Fox Body fan to ride with me to confirm I am not overly optimistic. I have ridden in many newer fast cars since the '87 and maybe its the reality of how performance has advanced. My other option is to take it to a reputable shop and ask them what is wrong/what is needed to make this scream.
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    Yes, stock AODs are ****ing terrible. You need a converter.
    2014 M235i (wife's)
    1964 Ford F-100
    Best mod @ that power level is a third pedal!
    Farmington WV
    4,672
    what rear gears are in it?
    And most likely a stall be good in it. my old fox had a stall and was more fun.
    1990 lx silverworm's Avatar
    monroeville pa
    309
    When i switched my fox from an aod to a t5 it literally felt like a 50hp increase. Aods suck
    Zoom50
    Dec 2013
    Tarentum
    97
    Quote Originally Posted by J-rod View Post
    Stock gears. 410's are on my list, but I am going to consider a swap before I invest in them. Anyone recommend a conversion kit? Any shops you would recommend to do a swap? What kind of labor am I looking at? I may have an aod with PA valve body for sale soon.
    Brookline
    2,897
    Yeah you definitely need to go to the darkside. Would be a fun car with a stick.
    Gears would help big time. Full t-5 swap plus install will run you over 2k.
    1969 Camaro restomod/project
    1967 camaro
    2011 mustang procharged
    93 reef blue notch blk/int
    92 calypso notch blk/int
    86 t-type
    1972 chevelle project
    Jeez - I sold my T5, bell, clutch, flywheel, and hurst shifter 2 weeks ago...
    Farmington WV
    4,672
    Stock gears 2.73 or other?
    Weren't most AOD cars 3.27's?
    Farmington WV
    4,672
    I wasnt sure.
    My 94 AODE is 3.27
    Zoom50
    Dec 2013
    Tarentum
    97
    I think 273's were standard for the aod and 327's were an option for aod Mustangs. I will have to look at my diff tag.
    I think you are right zoom. Most AOD cars I saw were 3.27's but that appears to be the optional ratio, as 2.73's were standard.
    Somerset Co.
    2,907
    ^^^ this
    Junior Member
    Nov 2012
    13
    Makes sense. AOD. Stock gear. E-303 cam which kills your low end torque anyway. Just a miss-matched combo.
    yes, a converter and gears will change things quick! Im not a big fan of the gt40p heads, I havent seen much real good power with them, the regular gt40 head seems to work alot better. a set of edelbrock e-street heads and a better cam would wake the motor right up. what intake manifold?
    Big member venom's Avatar
    North Fayette Township, PA
    1,344
    Very old post
    2015 GTPP
  1. lookin for b&m shifter for a aod fox
    By stangfever in forum Ford Parts
    Last Post: 12-20-2010, 05:51 PM
  2. WTB Clean Fox 87-93 5.0, AOD pref (at the moment)
    By wht88cpe in forum Ford Parts
    Last Post: 10-25-2010, 05:49 PM
  3. AOD LX fox hatch
    By gtboost02 in forum Ford Vehicles
    Last Post: 12-15-2008, 05:50 PM
  4. Aod,or C4
    By yeahloh95 in forum Ford Parts
    Last Post: 11-05-2008, 12:16 AM
  5. How LAME are Colts fans......
    By 1wykdmk8 in forum The Bar
    Last Post: 02-25-2007, 10:25 AM
