Results 1 to 12 of 12
Thread: 93 Bucking Sometimes a small intake backfire
    I am getting some bucking under light/normal acceleration. Fine at idle, fine at WOT. Timing 14*, FP 39-40. TPS .99V. Valve preload fine (hyd cam) No apparent vac leaks. Trickflow heads, cam,intake, 70 mil TB, 76mil MAF and so on.
    I built this car like 15 years ago. It has always ran perfect. Started doing this last fall before storage. So about 100 miles ago. lol I dont drive the car at but starting to now. Need it to run right. I have had a handful of these cars and always have them dialed in. Just want to see if anyone has had and solved this issue before I dig in further.
    Polar Vortex
    6,031
    Try cleaning the Maf.
    Thats something I havent done in a while. Good idea! Its funny, have put so many of these together.... never had an issue. Funny overtime even without much driving they get mad! Like a carbed car!
    1,220
    Sounds like a bad spark plug wire or other ignition problem. Do have a way to get a scope on it?
    Member silvernotch's Avatar
    Bethel Park
    664
    we got some afm wires, and a 331 that doesnt buck, that will fix it.
    Polar Vortex
    6,031
    Yeah they're also getting old! Lol. Can get an antique plate for a lot of foxes already, crazy how time flies. I do know that a lot of tuners stay away from these cars due to wiring issues. I guess old harnesses ect. give them fits.
    State College, PA
    3,552
    This happened to me before and it ended up being a bad ground. My car would only do it under some load like yours. Idle was fine. You checked all the usual stuff - timing, FP, TPS. If cleaning the MAF doesnt work and you can rule out the plugs/plug wires, I'd start checking grounds. May be a bad TFI module as well?
    2013 Mustang GT
    1999 Contour SVT
    Crazy right! Ya, my wife has an antique plate on hers. My dad didnt understand when he saw it until I told him to count!
    Well I did everything. Down to regrounding. Decided last shot was a distributor. Put one in from the junk pile. BOOOOOM perfect. I dont know why, I dont care, the old one looks great, great output. Whatever reason another stock distributor fixed it up.
    Car runs like a top. Now to find some stock E7s (well should do at least Gt40) so I can grab these twisted wedges for something made in the 60s!
    Does anyone have a set of Gt40/e7s and an exploorer intake? I dont want to really put all the E7 top end back on. Leaving that cam in so should have something better than stock. If I get some Gt40 stuff I will port match and clean up the bowls bla bla bla. God I am out of the 5.0 stuff. Sorry for the negativity! I need to snap back in.... my wifes car need some powa!
    Glad you were able to find a fix. What are you putting the TW's into Colin?
    1,164
    I still have a pair of lower mile e7s that I originally told you about.
  1. Anyone have a small Xcavator?
    By venom in forum The Bar
    Last Post: 12-01-2010, 12:27 PM
  2. Looking for a small refridgerator
    By BoneCrusher in forum Wanted
    Last Post: 12-15-2009, 09:37 PM
  3. Need some small stuff
    Last Post: 04-20-2008, 04:39 PM
  4. BAD backfire HELP!!!
    By delldoe in forum S197
    Last Post: 02-07-2008, 11:09 AM
  5. Small problem
    By 93Cobra5.0 in forum General Tech
    Last Post: 03-14-2007, 08:42 PM
