Page 1 of 3 123 LastLast
Results 1 to 20 of 43
Thread: Ranger finally made some passes
    Senior Member Dan B.'s Avatar
    Sep 2009
    Armagh, PA
    4,331
    After cancellations and rain outs, I finally got the Ranger to the track to try out the 387W/PA C4 combo. Got in four passes and drove it home.....success!! Each pass was void of drama........line lock, rev to 3k in first, 4k in second and roll out. Staged, foot braked to 2K and wacked it when the light dropped. It hooked great and went dead straight...success again!! All four passes went 12.50-12.55 at 104.9-105.5 mph. 60' times were 1.69-1.73. Over the old 351/C4 combo I gained 1.4 seconds and 7 mph. The trap speed seems low since I saw 13.50 ET cars also going 105mph.
    For a vacuum secondary carb and 3.55's w/ 28" rear tires (325/50-15 MT DR's) I think I'm content. I know......a vacuum carb....yuckl!! Yes.....but it's so smooth on the street and I drive this thing a ton. I have a good 750DP on the shelf and 26" ET Street mounted on extra wheels. Need to throw them on for the next trip down and see what happens. Also have a set of 4.56's ready to rock on the shelf but pretty sure I'd run out of RPM's before the end of the track....unless someone can convince me otherwise!! ;)
    Quote Originally Posted by John4cam View Post
    Ahh fuque
    1985 Ranger--2WD, basic bolt-ons and tires, 11.92 @ 111mph.
    1986 Ranger--2WD, 5.0/T5/8.8.
    Member travj31's Avatar
    Uniontown
    1,688
    nice times... congrats
    Nice runs Dan - VERY consistent, especially considering it is a new combo for ya.
    Quote Originally Posted by Dan B. View Post
    Never out of RPM's, just not enough of valve train or connecting rod :D :D :D :D
    Good to see you leave the track happy, that is ALWAYS a good first step ;)
    Senior Member Cam99's Avatar
    Melcroft
    4,178
    Nice Dan, congrats on getting it down the track and back!
    adult daycare speedracer's Avatar
    Somerset Co.
    2,907
    Quote Originally Posted by Martin0660 View Post
    Lol!!!
    Senior Member scott5's Avatar
    NC
    10,168
    With the 26s I think you will pick up some. Congrats on the Times.
    Nice runs, congrats! I saw the Ranger going down track in between wrenching on my junk, and never put 2 and 2 together. Nice ride, runs great! If you bracket raced, I'd agree about dumping the vacuum secondaries carb, but you've got a good set up now it sounds like. Is the carb on there a 750? Maybe jet up a little, see if the mph improves. Nice 60' times too. I like the idea of trying the 26" tires.
    ChuckT
    Sponsored by
    Wholesale Transmission - New Kensington
    Millerstown Pic A Part
    Sep 2009
    Armagh, PA
    4,331
    Yes....carb is a 750 Holley vac w/ the lightest spring.
    At this point I'm torn. Would really like to see an 11 second time slip but don't want to be jacking it all up for street driving. If it could happen with gears and tires would be great but don't think that will do it. Would really like to take it somewhere and have it tuned on a dyno to eliminate any guesses as to what it really would like for timing and carb.
    What were you wrenching on?
    Ahh fuque
    NC
    10,168
    Try the tires first if you have them. Imo with that gear your hitting yourself big time with the 28s. If you do change to a 4.56 the 28s it will probably work out at the same as the 3.55/26 setup.. and a street setup with 4.56s and auto aren't fun.
    My fast car runs a 3.90/th400 and a 275/60/15 et radial pro and slow car runs a 3.73/4l60e on a 315/35/17 Nt05r. The slow car gained .3 but lost mph when I put the 275/60s on it. It was all in the 60'
    Drive to track make passed and drive home....success!!! Great times and good 60' for not much converter and gear/tire combo. Ever had the truck on scales?
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    Dan I know we talked a bit about the carb, but I don't see why you can't make the mechanical secondary carb work on the street. My '64 and every other car I've had a mech carb on had very acceptable drivability. Before I went too crazy I would absolutely get it on a dyno (you'll probably find 30hp), and I would try the 26" tire before I touched anything.
    The mph is a bit low (but 13.5@105 isn't the norm), with your 60' I would expect 108-109. Even more reason to tune it on a dyno or at least get a wideband, sounds like it is lacking on top for the mph to be low.
    2014 Mustang GT Stock and for sale
    2014 M235i (wife's)
    1964 Ford F-100
    joe THE BIG KOALA's Avatar
    Feb 2009
    Vandergrift
    1,117
    Nice talking to you at the track
    2019 Hellcat
    2015 Norwalk NMRA true street 13 second winner
    NC
    10,168
    Race weight?
    Sep 2009
    Armagh, PA
    4,331
    Think the truck weighs around 3400-3500 w/ driver......I'm not exactly a horse jockey but not Hulk sized either. The convertor is a Hughes 3500. I do have a wideband....at idle and cruise it's right on. Idle is around 14 and cruise is high 12's to 13. But WOT is goes rich.....mid 11's.
    I've driven mech sec carbs on the street before and never had issues. But I like the smoother part throttle driving of the vacuum. Maybe over the long weekend coming up I'll swap carbs just for you Mark!! That and a tire swap.....then maybe see what happens next week for weather and try to make some hits at the track.
    Ahh fuque
    I was wrenching on my Cutlass, putting the engine back in. It broke a lifter, thought I had wiped out the cam. Couple of bent pushrods too.
    I agree with Mark about your mph, and the 13.50 at 105mph. I also drive my mechanical secondary carbs on the street, 850 when it had the big block, 650 on the small block.
    If you can make Saturday at PRP, the weather looks awesome. You'll get about a tenth right there compared to last Thursday. If those 26" are DOT legal, you can run Trophy for $25, guaranteed at least 3 runs (2 times trials plus first round of eliminations). Not that I put much faith in a forecast 8 days away, but next Thursday is looking wet.
    ChuckT
    Sponsored by
    Trafford, Pa
    2,308
    Dan, if your A/F is in the 11s at WOT you are leaving a ton of hp on the table.
    2014 M235i (wife's)
    1964 Ford F-100
    Sep 2009
    Armagh, PA
    4,331
    Quote Originally Posted by Mark Aubele View Post
    Can anyone recommend a good tuner that works on carb'ed vehicles??
    Ahh fuque
    Uniontown
    1,688
    How far you willing to drive? I know a couple of guys that are great, but they aren't that close to you and it's hard to get them to work on things sometimes.
    Sent you a text Dan.
  1. First passes of the season
    By Martin0660 in forum Pictures & Videos
    Last Post: 04-17-2012, 02:23 PM
  2. Passes from 8/11/11
    By Ares in forum Drag Racing
    Last Post: 08-13-2011, 08:19 PM
  3. I made my debut passes at PRP last night
    By Killercanary in forum Drag Racing
    Last Post: 10-29-2007, 10:52 PM
  4. last of my three vid passes from 10/15
    By 04snake in forum Pictures & Videos
    Last Post: 10-10-2007, 01:01 AM
  5. Free Movie Passes!!!!
    By PHFIRENO7783 in forum The Bar
    Last Post: 05-25-2007, 11:52 AM
