Results 1 to 3 of 3
Thread: Wheel Offset on GT/CS wheels
    3,316
    Can someone verify my google-fu is correct please?
    The GT/CS wheels are the same as the V6PP wheels in that they are both 19 x 8.5 with 50mm offset. Is that correct?
    Since the stock wheels are arguably (depending on who you talk to) too narrow for a 275 tire I'm considering taking the plunge on these:
    http://www.americanmuscle.com/black-...0513.html#tab2
    If the 50mm offset on the stockers is correct, then these at 35mm offset with a 275 tire provide the same clearance to the suspension as stock and only protrude outward a bit more.
    verification of the offset is appreciated.
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    I like those. Thinking of getting a set in 18x10 for the A6s. Would you mind weighing one for me when you get them (if you do)? I know they are a different size but I just want to make sure they aren't like 32lbs...
    2014 M235i (wife's)
    1964 Ford F-100
    3,316
    Sure thing Mark! I am really torn on getting them or not as my original intent was to "pimp on a budget". If I decide not to be completely cheap and put the tires on my 8.5's, I'll be glad to weigh them for you when they arrive.
    EDIT - can u verify the offset I found? :)
  1. N.I.B. Energy Suspension Poly Offset Rack Bushings
    Last Post: 10-01-2013, 10:41 AM
  2. widened wheels/wheel spacers
    By whitesnake in forum SN95-New Edge
    Last Post: 03-06-2013, 08:07 PM
  3. i need one wheel for a 98 v6
    By schiavon8241 in forum Ford Parts
    Last Post: 08-12-2008, 01:57 PM
  4. 5 X 4.5 Wheel
    By eddmann55 in forum Ford Parts
    Last Post: 08-11-2008, 10:52 PM
  5. Replies: 1
    Last Post: 11-17-2007, 02:03 AM
