Results 1 to 14 of 14
Thread: What head gaskets do you like??
    Power Adder
    236
    Well it's time to swap my trick flow heads on after my driver side head gasket blew out. I have all the gaskets I need other than head gaskets. I was just wondering what ones you guys like and have had good results with. One thing to keep in mind is I plan on spraying around a 150hp shot and I do have ARP head bolts.
    Chris Kauffman
    1988 408LX drag car
    out in the woods
    4,948
    ones that dont leak are nice... lol
    j/k
    never had to put any special gaskets on, always went with this hi/po shop in uniontown for gaskets
    3,356
    Cometic.
    Mark
    LeMans Blue Z06
    shaler,pa
    1,010
    I always use fel pro hps. Never failed me and i spray mine with a 100 way to much.
    Power Adder
    236
    Well I have the engine all torn down and found out why my driver side head gasket failed. When I went to pull the front lower head bolt it was already loose. I was like WTF, and pulled it out. Looks like it had broke right at block level about a month or so ago. Lucky I was able to use an easy out to get the rest of the ARP bolt out.
    Chris Kauffman
    1988 408LX drag car
    The arp bolt broke??
    Wow!!
    shaler,pa
    1,010
    Yea dont hear of that.
    Wow!!
    Power Adder
    236
    Ya, this is a first for me for an ARP bolt failing. I'm going to call them tomorrow and see if they'll give me another bolt. Heck she was only putting down a little over 200rwhp :)
    Chris Kauffman
    1988 408LX drag car
    Member itow's Avatar
    Warfordsburg/Breezewood, PA
    107
    With my latest combo, I am going to run the Fel Pro MLS gaskets.. Many of the big HP people run them with great success. But, the head and block surface has to be SUPER smooth for them to seal.. Almost like mirror smooth. If you can feel any ridges with your fingernail, it aint smooth enough..
    Huntingdon PA
    1,136
    I use just regular fel pro's. in MHO it's better to make the weak part your head gaskets. That way should something go wrong your gaskets fail first, instead of you having an internal meltdown. Cometics should guarentee you get down the track though if your looking to get down there one way or the other hehe.
    709RWHP/750RWTQ
    I LIKE felpro 1011-2's
    Power Adder
    236
    Well here's the felpro gasket after I pulled the head off. I also called ARP and they told me to mail the head bolt back and they'd mail me one in a week or two. I asked if they wanted the other one's back just incase they fail, and they said nope. So I passed and had to order a new set so I didn't have to worry about them breaking.
    Here's what she looks like far with the new TW heads and pro com rockers :) Just need push rods and she's almost done.
    Chris Kauffman
    1988 408LX drag car
    1011-2s or cometic... ftw
    I was going to run 1011-2's on my car temporarily (I have a set of fel pro MLS gaskets for when the turbo goes on) and I sent them back and got 1011-1's per AFR's recommendation. The 1011-2's have a copper fire ring where the 1011-1 have a steel fire ring. AFR tells me that have seen to many failures of the 1011-2's after just the slightest amount of detonation, even on NA motors. The fire ring seems to rattle itself loose from the gasket material. I have no personal experience with this, but I figured I'd post this info here for you.
    I always ran DG "orange" gaskets on my old combo and I loved them. They had a compressed thickness of around .035" but they are no longer made.
  1. gaskets on intercooler?
    By frcefed in forum Fox-SN95
    Last Post: 03-27-2011, 11:27 PM
  2. Anyone know where i can get intake gaskets?
    By 2001GTTT in forum General Tech
    Last Post: 10-08-2008, 12:06 AM
  3. Head gaskets
    By lib88stang in forum Fox-SN95
    Last Post: 08-10-2008, 03:25 AM
  4. Felpro Intake gaskets
    Last Post: 06-30-2008, 01:28 PM
  5. gaskets
    By eddmann55 in forum Ford Vehicles
    Last Post: 01-20-2008, 01:25 PM
