twin disk rst or single disk spec 3+......
1. pros and cons ???
2. experiences with either ????
for an 04 cobra
any and all info is helpful thank you...
for an 04 cobra
COREY...
*04 Torch Red Cobra
1 of 164 with med.graphite inserts
Work done and Tuned by Rodeheaver's Hot Rod shop...
471hp/489tq
*1970 chevelle ss L-S5 454, 4 spd
real deal not a clone have paperwork
RST twin disc will burn up at the track despite its HP rating. I was told by Tony at Astro and Stan Peace ( Astro builder ) to go with the RXT between my 331 and my Astro A5. The RXT is a few hundred more bucks for my application ( still allows the use of my flywheel ) but is supposed to be very streetable and as durable as they come. I can't wait to get the car back and find out! I heard the Spec has a higher pedal effort and is less streetable than the RXT. Also - the twin disc will be much easier on the tranny - less driveline shock. Not sure if that is a problem with your already beefy T56.
Mike - what is your experience with the RST vs the RXT? They are both McLeod twin disc clutches. Do you agree with what I posted above?
I usually do the RXT but have never had any negative feedback from the RST. They will all burn up at the track, it's a wear and tear component but for the minimal money difference, we usually go with the RXT. Spec is a terrible company, don't care for the products much...
thank you guys for ur input....
COREY...
*04 Torch Red Cobra
471hp/489tq
mike i have a new spec billet steel flywheel will it be ok to use with the rxt??? i kno sum say to use mcLeod's flywheel...
COREY...
*04 Torch Red Cobra
471hp/489tq
