1979 Malibu Wagon
Had this listed a while back and I started tinkering around with it again so I pulled the ad. Anyways, life got in the way this summer and just didn't make the progress I wanted to so I'm putting it back up For Sale or Trade - no boats, swamp property, Jap crap, major projects, tools, ex-wives, etc.
Motor is a well built 377 stroker SBC. Has 13.5-1 compression, SCAT crank, 5.7 Chevy rods, Forged Speed Pro pistons, World Sportsman 200 CC iron heads with 64 cc chambers, and 2.02/1.60 stainless valves, chrome moly pushrods, full aluminum roller rockers, COMp solid lifter cam 250/260 duration @ .050 and 532/55 lift, Pete Jackson gear drive, Victor Jr intake with brand new 850 Proform HP carb on top of a Wilson nitrous spacer - wired and plumbed for a 125 shot, with new 110 GPH electric fuel pump and Holley regulator.
This thing sounds NASTY !!!!
Tranny is a Turbo 350 with a brand new Freakshow Performance 5000 stall converter with a new B&M Z Gate shifter, and a new deep aluminum pan.
Car is wired - headlights/tailights and runs on toggle switches and push button start, has a new 4 wire alternator, new oil pressure and water temp gauges, has 5" Autometer Tach with shift light and recall. Also has an electric fan from a Grand National to cool the rad. Car also has 2 fiberglass racing seats, and installed driveshaft safety loop.
Car has GM 10 bolt, and comes with a mini spool. I also have a stock hood with a small 2 inch hood scoop for it and hood pins.
Buyer also has option of wheels/tires - The aluminum slots pictured or a set of mismatched big littles mounted to 11.5 inch ET Drags. Both sets have great tread life remaining.
I believe this car can and should run deep into the 11's NA if not faster. 10's should be no problem on the 125 shot.
Call or text 814.442.7631
$5000
