Results 1 to 8 of 8
Thread: 96 Cobra IRS Swap
    Oct 2012
    Glassport, Pa
    177
    96 Cobra IRS Swap
    Anyone here do an IRS into a SN95? I am planning on doing the swap and it would be good to know someone that has gone through it.
    Alot of people say to use this 'T', but can I use this hard lines from the 'T' to each soft line? (I am planning to use MM Braided hose) How do I go about flaring the fitting onto the brake line from the front of the car after its cut to connect it to the 'T'?
    I think John (Somethingclever ) did this swap - before his car was hit and he parted it?
    Oct 2012
    Glassport, Pa
    177
    Just picked up my IRS today! Looking at getting everything ready and having a game plan before I go ahead with the swap.
    i was all worried about that t and the brakes and once i got it done it was no big deal once you run the braided lines in towards the center of the car , you just need a small section of hard line to the t i got mine with ends already on . if you need help just pm me
    Somerset Co.
    2,907
    I'd get the FTB kit put in while its out of the car... Gears? Upgraded Diff cover?
    Oct 2012
    Glassport, Pa
    177
    Not now, I am going to upgrade the bushings down the road. Same with gears.
    Thanks, I am looking to 'T' the brake lines but I don't have experience doing that.
    take a pic of the current fitting under the car and we can get you hooked up
  1. 99-04 cobra,IRS parts
    Last Post: 02-09-2014, 07:53 AM
  2. FS: cobra IRS
    By wickedsnake03 in forum Ford Vehicles
    Last Post: 02-06-2010, 12:01 AM
  3. Feeler for IRS to solid swap
    Last Post: 10-18-2007, 11:45 PM
  4. 2001 Cobra Irs
    Last Post: 04-09-2007, 02:43 PM
  5. Wanted Swap IRS for Solid
    By SilverFox in forum Ford Parts
    Last Post: 02-05-2007, 09:36 PM
